Mini Crushers
Maxus
The hopper is 2m off the ground, feeding it any other way than with an excavator is just not practical. In the end I loaded the hopper, then hopped up onto the stand and effectively fed it by hand, and when needed switching on the vibrating hopper to shuffle along the material. Yeah, it was an absolute pain in the arse, the remote also wasn't working properly and would only work plugged in to the mains, on charge so to speak, and on top of that the charging cable was basically broken and kept shorting out. Even bricks you had to feed by hand. I think one of the jaws (the stationary one) needs replacing as the top third is completely smooth. I've renamed the machine 'red retard 5000 plus'... it got the job done... just.
The hopper is 2m off the ground, feeding any other way than with an excavator is just not practical. In the end I loaded the hopper, then hopped up onto the stand and effectively fed it by hand, and when needed switching on the vibrating hopper to shuffle along the material. Yeah its was an absolute pain in the arse, the remote also wasn't working properly and would only work plugged in to the mains, on charge so to speak, and on top of that the charging cable was basically broken and kept shorting out. Even bricks you had to feed by hand. I think one of the jaws (the stationary one) need replacing as the top third is completely smooth. I've renamed the machine 'red retard 5000 plus'... it got the job... just.
Sounds like a s**t hire company.
