Vinnys Ventures
what about one of these old style units ... could be had for peanuts at auctions - binned one in my clear out, I'd bought for sod all but never got round to installing
crate serious levels of hot air - can be thermo controlled and a remote set uo would be a POP with what's available these days
can also get multifuel jobs too
I used to have a ticket for working on the Gas/LPG Variants of these. Bit dated now and always the potential to kill you.
OPs shed is insulated and 14m x 8m maybe? Probably only needs about 6kw to keep it ticking over. I would suggest a pair of chinese deisel heaters working from a common fuel tank, and keep a new one as a spare.
Just getting the duckling ready for action ! It’s now got the steelwrist fitted . I had to switch to control system as the 4 pipe didn’t work well enough which was a bit more expense and had to wait longer for bits to come but Angus done a great job of fitting it . Needs tow bar attached to blade now , then ready for site I might go for next size down in grader . It seems to handle it ok but might be a bit lively fully loaded . Also BMC forks need adjusted as they won’t rotate because the cradle is to near the rotator . That will get done in next couple days ready for site next week
yeh I had considered that as a suggestion too ... impressed with the heat mine chucks out and as you say, with all the insulation Vin's installed it wouldn't need much to keep it toasty, once up to temperature - easy enough to run a fuel line to, inbuilt pumps, could do away with their integral tanks and feed from a bigger reservoir of fuel (y) :cool:
looks a great shed @Vinpetrol We are looking about with a view to downsizing - straight through the ads to the bit about the sheds and outdoor space, bollox to the house, leaving my shed here behind will be a tough day 😂
exactly what Russ bought ... spectacular workshop, with 3ph, pits and an overhead gantry, with commercial plannning and great access, out in the sticks .. the cottage with it was secondary ... knocked it down and built an oak frame to his spec. .... total paradise :giggle::giggle::love:
when i bought Chez Druid the only box it didn't tick was 'a shed' --- but room for one :rolleyes:
Just getting the duckling ready for action ! It’s now got the steelwrist fitted . I had to switch to control system as the 4 pipe didn’t work well enough which was a bit more expense and had to wait longer for bits to come but Angus done a great job of fitting it . Needs tow bar attached to blade now , then ready for site I might go for next size down in grader . It seems to handle it ok but might be a bit lively fully loaded . Also BMC forks need adjusted as they won’t rotate because the cradle is to near the rotator . That will get done in next couple days ready for site next week View attachment 86068View attachment 86069
It is S40? @DaveDCB has a n Engcon grader at the right money but not sure how it compares size-wise to your existing bucket.
I think I already did this with Dave , I think it’s the same size . It’s a steelwrist GB 5 and Dave’s is a GB05 they are virtually the same . I want a lighter less volume one . Steelwrist do an 1100 wide one . I actually think unless tilty is mounted with a dedicated hitch then they are nearly all to big
W
What was the problem with a 4 pipe setup?
Looking good mate.
W
Looking good mate.
Something to do with open centred hydraulic system , oil goes to first port demanding it so can starve the other ports . Apparently it’s ok for a shear or rotate and tilt separately but not trying to use it together . Definitley a bad point of the machine .
W
Looking good mate.
