Mini Crushers
jodb69
jodb69
Hi All
Took down a load of walls out on a big project, (old victorian red brick) , prob 40- 50 ton.
Was thinking of crushing cause got some landscaping and other uses for hardcore on the job. Was going to mix it up with some type 1 with telehandler where type 1 is required ( some internal floors etc).
Was looking at Red Rhino 4000 or 5000.
I read mixed reviews on them but thought as the brick is fairly soft it would crush easily.
Hoping to load with on site 1.7t TB216
Anyone got any experience with them??
TIA
Fms1
Fms1
I have a R/R 4000 and will eat through brick as quick as hand fed, have loaded with machines including a 5 toner but just means you’re waiting for it to clear before adding the next buckets worth.
its never going to be an “industrial” crusher but will certainly do what it sounds like you need.
jodb69
jodb69
Thanks for replying
I looked at the 4000 but thought it looked a bit small, you think that would be better for loading with 1.7t?
Was going to put tele bucket at other end and carting it straight off
Fms1
Fms1
Thanks for replying
Will be fine with a 1.7, I often fill the tracked dumper or a bulk bag
jodb69
jodb69
Would you even bother with a riddle bucket on a 1.7t, they look like they wouldn't be very effective.
The brick pile is relatively clean but I have a 20t pile that's not so clean.
Do the rhino's jam up much?
groundworker
groundworker
I've got a rake riddle on 1.7t and it works fine on dry gear.
When I've had those mini crushers before we fed by hand as they jam easily with bricks.
It was a different crusher to the Red Rhino but will also eat bricks as fast as you can drop them in.
William127
William127
I used a general purpose rake bucket on my micro when I was loading a mini crusher, found it ideal as I could bite into the pile nicely and shake out the smaller stuff so I had decent lumps going into the crusher.
Maxus
I've got a red rhino 5000 on hire next week, I have approximately 22T of mostly concrete, had anyone used one and have any pearls wisdom that'll save me a headache? I really need it to all get crushed in 1 day! Otherwise I'm going to be out of pocket..... I have a labourer armed with a sledge hammer helping me
groundworker
groundworker
I think you'll be fine, the RR certainly looks bigger than ones I've hired in the past and we've managed similar/a bit less in a day.
It depends what size material you want, if you run the jaws wide open you'll have no problem but I don't like working with 75mm lumps. Crushing to something like type 1 size is way slower.
The main thing that will slow you down is blocking up the jaws, so look up the jaw size and smash your lumps of concrete up small enough to fit through beforehand.
You will most likely be able to feed it with a trenching bucket on the digger and have the labourer watching over the hopper with a poking stick.
William127
William127
The red rhino I hired was supplied with a metal pokey stick 🤣👍
I also had a hop-up so I could stand up and see inside the hopper when clearing it.
Both times I hired one it was only worth doing as the access was crap.
Maxus
Red Rhino 5000 plus - what a nightmare! Didn't help that the machine wasn't working properly, I did say to the man after half an hour that it wasn't, but alas, what would I know? Took a video and at three o'clock, after a day of struggle, looks at the message - 'oh that's definitely not right!'. Jaws after replacement were loose...
Annoyingly going to need another day with the machine which I won't get charged for due to the circumstance. Unfortunately labourer won't be there, but now the machine is working properly it shouldn't be too difficult.
It is a decent bit of kit though I have to say, it produces a good material and (when working properly) does get though it.
Trying to feed it with a bucket was your first mistake! 🫣
Trying to feed it concrete was the first mistake...... I have only ever seen one working Rhino.... That was a 5000 that had died terminally (engine) and had been rehabilitated with a Perkins phaser, doubling the horsepower.
They will munch on bricks..... Try to feed it anything that actually needs crushing will result in great sadness
