Handy things the tilties. I’ve had a couple of days restoring wildlife ponds too this week. The last couple of pics are the tip, which was a failed pond that is earmarked for ultimately filling in (it’s very rocky ground and the ‘tip’ pond apparently never held water).
There was 150ish tonnes of sloppy sticky shite to dump, so I used it to puddle the failed pond and am fairly confident it will now hold water. (I definitely won’t get a job as a plasterer but it’s very easy to do this sort of thing with a tilty).
There was 150ish tonnes of sloppy sticky shite to dump, so I used it to puddle the failed pond and am fairly confident it will now hold water. (I definitely won’t get a job as a plasterer but it’s very easy to do this sort of thing with a tilty). View attachment 85552View attachment 85553View attachment 85554View attachment 85555View attachment 85556
Ideal use case.
have you borrowed Rory's old camera Dan or was it foggy ?
Simon edwards
Simon edwards
First day on the new 5 tonner Friday, just moving spoil but gave me a chance to get a feel for it,reach marches the old u55, it’s actually deceptively quick on a loading cycle just doesn’t quite feel right yet,weirdly I think this is because it’s so quiet compared to the Kubota which was very not quiet!
I think it will grow on me after a few more hours,so far so good.
Trying to post pictures but the last while I’ve just gotten “picture is too big to upload” what am I doing wrong??
Is it a fairly new iPhone? The images are massive - you might need to take a screenshot of the photo and post that instead (as daft as that sounds!).
(I had the same problem until I ran over the new phone with the forestry mulcher - the old second-hand one I’m back to using posts pics fine 😂)
Had to sort this spillway at a trust property, drain outlet from pond was shooting straight across and destroyed the wall, rebuilt wall, concrete thrust block behind it, rebuilt weir , added 45 bend to direct water down spillway. Took some getting on the 45 degree and they’re like £350 in 500mm!
Temp works and setup take longer than job on jobs like these
