So quick. Embarrassingly easy to make humps for water runoff.
Or an underground larder before the advent of fridges. My others half's dad had a country house in Sweden that had something for this purpose looked similar.
was gonna say similar or ice house, but could also be a water tank?
Usually concrete. At least all the ww2 stuff I have seen devon/Cornwall and islands is concrete. The German structures on Alderney were something else.
Agreed that's prewar imo. Looks more like a culvert to me apart from the interior looks solid. What the pipe in middle of back wall? Weird
Quite a few brick ones in this area. We have a lot more clay than we do aggregate. But even then it's usually a concrete roof and flat.
quite a few brick 'pill boxes' round here too -- with flat concrete roof
Up in the moors attempting to fix this bridge, getting access to it has been half the job, big 4” pump is awesome. Everything is fetch in on trailer as no access for anything big, few mile long track in from ranger base.
Bridge is on an old reservoir and the level is at reservoir level so had to dam it both sides culvert it with 300 twinwall and pump it to work under bridge. Then it’s waders and on knees as no room under there
How the feck do you price that?
Experience and
Hopefully correctly lol but has taken a few days longer to dam it than I thought but hopefully repair goes quicker
Helps having all the kit in house and a head for problem solving
Approx £18k for this bridge with £4k of that being temp dam and bypass but had all twin wall and new bulk bags in yard from other river projects
How will you repair that collapsed stonework? Looks a nightmare!
What has caused it to fail - massive flow, overloading, or a bit of both?
Got the grab onto the T450 and cut the blade bolts off- lets see how she does stripping bracken litter. In theory is the perfect thing.
Checked the oil levels and topped up the hydraulic. I'm always amazed at how tiny the tank is on this- I guess it's not like a digger where rams can be in all kinds of positions requiring a wide range of levels. And the cooling pack is chunky with a hydraulic fan. But still- only around ten litres plastic tank on a 65hp entirely hydraulic machine!
I'd guess looking at that the foundation stones have either sunk/undermined and as soon as that happend the locking effect of the keystone arrangement above failed. Not an easy repair for sure.
Checked the oil levels and topped up the hydraulic. I'm always amazed at how tiny the tank is on this- I guess it's not like a digger where rams can be in all kinds of positions requiring a wide range of levels. And the cooling pack is chunky with a hydraulic fan. But still- only around ten litres plastic tank on a 65hp entirely hydraulic machine!View attachment 85078
Seems like your getting plenty of use out of the T450👍
