It's easily done, but 3.5t tipping trailers are heavy enough as it is. And elsewhere in this thread, you have multiple people referencing low load heights as a selling point.
It could probably be done with a hinge in the chassis behind the rear axle. Would just require a fancy design so a single ram would lift the back of the trailer first then tip it without adding to much weight.
I think larrington hi tip trailers work like this so as to keep weight down.
