Mounting a ripper?
Spurry
Having just reached the stage where I can change a bucket with dropping off the top hitch too, :rolleyes: is it posible for an experienced user to pick up a heavy ripper sitting sideways on a pallet? It weighs 168lbs. Obviously the easy way out is to make some sort of stand so the attachment sits with the pins horizontal, but is this something that it is possible to achieve without such a stand and a lot more experience?
The Steelwrist design is a prick, it's got a very narrow window where it will balance to be easy to pick up.
I'd do as Graham says above, you'll just pull it off the pallet trying to hook it as pictured.
personally I'd very short choke sling the furthest pin to the tip link and suspend it upright - tip of the ripper on the deck and manipulate the dipper tip between the cheeks, 'til you could get a pin into it ... choked to the link, (or hook-if it has one) would help in getting it somewhere near right and give you some movement using the link
Stick it in the ground when you take it off to make it easier to pick up next time.
he's gotta get it off the pallet and onto his dipper first Dan :ROFLMAO: :ROFLMAO:
for future, make a plate with two ears sticking up to keep it on its back with the pins horizontal - make the ears long enough to put a keep pin across it so you can lift the plate with it for loading/unloading/parking ;)
Spurry
Thanks for all the hints and tips. It lives on a pallet on a shelf, so cannot stick it in the concrete floor, ( not without making a mess ;) )
I like the idea of a frame, but was just curious as to whether those with more skill, experience and practise would load it from the position shown.
Will give Graham's suggestion a try, when I get a bit better.
grab it with the gripper ?
Thomas7740
Thomas7740
If it’s on its side, just push it over and hook it on at the same time, no stands or anything needed
This is how its done, a plate welded to the back like this which means it rests back on itself.
ooh im not sure that would stand my butchery 🤔 often up to the proverbials snappin roots ...its under a tilty so when its laid on ground on the job with a bit of practice it comes up and on at same time, not sure if op means how do i get it off his racking though ...
