more time and money than sense .. WTF would you do with that aside from bolting it to a go cart or similar
I like the "idea" of a supercharger, but the practicality needs to be justified (does it actually produce any more power?).
A dyno test before and after would be a good start.
One of the historical problems of adding a supercharger (mechanical mostly, but also applies to exhaust turbines) is where to put the carb - before or after the pump?
- before the pump is easiest, but the fuel droplets tend to come out of air-mix and wet the walls causing the air-fuel to vary according to revs
- wetting the rotors with a solvent like petrol can cause rotor wear.
Mounting the carb after the blower is better for many reasons, but most carbs are vented to atmosphere (for reference pressure) and don't cope with a positive pressure on the inlet. SU's are the common pick (the ref. pressure is sampled at the inlet)
Then of course there is lube and cooling - on an engine with no oil pump (splash lube), you can't add an oil cooler and you can't improve the oil flow.
Materials - will it hold together?
And a small problem of compression - force more air in and the compression pressure goes up - so you need high octane fuel unless you lower the compression (ie. drop the compression ratio for the same final pressure) or it will pink (pre-ignition) badly
Shows the way things are going!
9 mins to 80% charged!!
Tabless batteries are the next thing .
Festool just launched as well.
I get all the battery stuff For power tools and certain vehicles and plant. Glendale's where clearing out site and had all KRess stuff and was so quite, so much nicer than the old petrol stuff.
But something about all this battery stuff now just doesn't seem sustainable. And the battery charge times seem like a recipe for disaster, obviously I am no expert, and this might just be a conspiracy theory. But I'm sure something somewhere just doesn't add up about the motives for battery equipment and where the technology is going.
I get you and you know my feelings...
Just simply put this up as this is normal kit available where we gonna be in 5 years.
I'd never bother buying 2s now unless a big saw.
It must be pushing the boundaries of safety you'd think on heat and risk of a battery going pop surely?
You would think at some point, something, will go pop.
The electric stuff is very good now. But playing with it, none of it seems the quality of the 2stroke comparison. I don't know if this in just part of the ever crapification of products or they are trying to shave weight off. But definitely don't feel as robust as petrol tools.
I am also still pissed that my big top of the rage Makita hammer drill has packed up with not a lot of use. And the parts to fix it are as much as a new one. And I don't think any brand is immune to this now.
First Stihl strimmer was crap but since got the proper big kombi motor that takes rest of my kombi kit. It's a beast more powerful than the 2s imo now.
Today on the M6 - not just the lorry driver who was lucky....
been out with a crane many times to tranship similar loads that've gone through the cab :(
interesting fact .....
" No men left for German women to marry in 1945
In 1945 when the Second World War finally ended, beautiful Germany had no young men left. Millions of German soldiers died in the mud of Russia or during the bombs. Millions more soldiers were locked away inside Soviet prison camps for ten years.
There was a word in Germany, Frauenüberschuss. It means in english many women, not enough men. The official numbers from 1946 said there were 7 million women more than men. For the girls, between 20 and 25 years old there were about 171 women for just 100 men. The math was cruel. For a generation of girls finding a husband was impossible.
Instead of weddings German women had to do the heaviest work. They were called Trümmerfrauen, it means Rubble Women. German women stood in lines for hours clearing bricks from destroyed Berlin with her bare hands. They live their life in hunger instead of happiness.
When a few German soldiers finally back home years later, they were broken inside. They had missing legs, sickness and terrible nightmares. Because men were so rare the dating world became very strange. Some girls started dating the British occupation soldiers just to get food and survive. 14,000 German girls married US soldiers and went to America. For the millions who stayed behind a wedding never happened. They stayed single worked hard and rebuilt Germany alone. "
Bucket on wheels
Bucket on wheels
No more cold workshop 😎
1. build me one 🤩
2. keep it out of sight of the authorities 😑
because burning used oil in viking land can be expensive if they find out 🙄
