Hydraulic issues Kubota kx61-3
P
Plantman01
Anyone shed some light one this for me would be great.
I rebuilt hydraulic pump on my kx61-3, that was grand couldn’t get the system to bleed or build much pressure.. now there the only time I can get the machine to work is if I turn it off and start it up again, allowing some boom functions momentarily (very weak).
But my tracks are working spot on for around 10 seconds and then all of a sudden they start to judder then stop completely???
Turn machine off and on then it works again for another 10 seconds ?
Swapped PRV at spool valve to see would it help but it hasn’t.
Anyone any suggestions?
what sort of pumps are fitted to this - not familiar with the model ... have you tried reading any pressures anywhere need to determine if the pump(s) are making it and it's getting dumped or whether they're just not making pressure, first off
why did you rebuild the pump(s) ?? failure or just not making it ?? gear or VDP .. if the latter do you have any delta pressure - if not it just won't upstroke
P
Plantman01
Nachi pvd28P variable piston pump.
Basically the old one wasn’t doing the business, bought a rebuild kit. I can’t even get a good pressure reading atm because it won’t give me a good enough consistency to read if you understand me. It’s very strange. At the minute I have no pilot functions unless I hold down the tracking pedals and use the joysticks then I can get some movement , put a bit more revs on it and bang no power at all.. stop and start again instantly and we have powers. I’m not sure if it is just dumping back to tank or maybe I’m getting air? Could be a round the front seal on the pump.?
how good were the swash plates going back in ... they have to be perfect or you'll get no pressure
P
Plantman01
Photo of the pump please
is that a generic piccy?
or
you had the pump rebuilt by a third party ??
if the latter - chuck it back at them as there is obviously an issue
P
Plantman01
stripped pump down tonight and found out the retainer ring is cracked and bent and a few of the slippers are worn down… I see a lot of brass filings in the oil so going to have to flush that all out 🥺
What do we reckon now ? Why has this happened
above Q.s still stand
or
Do you mean the needle is bouncing up and down so you can't take a reading?
The Hydraulic Layout Diagram shows a suction filter in the tank, have you checked for blockage?
Sounds like the pump is cavitation (or sucking air) (in addition to it's other problems).
I'd start by pulling the return filter to find out what sins are present there.
Sorry this was a generic picture I had. I rebuilt myself. Need to order new parts as of now
without wishing to sound impertinent ... summat didn't go back together right to cause that level of damage in so short a time ... everything needs to be literally surgically clean before and during assembly and all components 'in tolerance' ... a grand's a lorrabucks to have to spend twice :cry::cry:
P
Plantman01
I’m beginning to question the quality of the rebuild kit. It was from Chinatown direct. As I said I have rebuilt these before and had no issues with using the genuine parts.
I’m on the verge of ordering a new pump at this stage and be done with it 🥹
Ok is the plate holding the brass parts actually straight? End on! From the side, so if you pulled all the pistons out and laid the grey bit on a flat surface is it flat?
P
Plantman01
soooooo, partly my fault partly suppliers fault.
They sent the wrong size of dowel pins 6.5mm too long- and I never compared them with my previous ones. Making the whole pump internals 6.5mm longer than needed. Which in turn damaged retainer ring.
Rebuilding phase as we speak. Will keep updated
er .... WOW !! :oops:
bit of a **** up ... :(
mostly on their part :rolleyes:
hope it ain't costing you a second kit:unsure:
or that it's not done any damage to the pump casings :cry:
look forward to hearing good news (y) :cool:
P
Plantman01
Been a while!! Haven’t looked at the Kubota since, after rebuild for the final time tracks 100% now, but still having issues with my servo movements, no power stall. Only I started it yesterday for the first time in a month and wahey had stacks of power lifted machine off the ground etc … then is left again.
Testing pressures at port 3- 170 bar (blade/swing circuit)
Port 4 pilot line- constant 35 bar doesn’t reallly change when I dead head a function. Very slow sluggish and weak functions… I know the system should be achieving 40 bar but that’s all I can get out of it.
Checked red lever solenoid replaced o rings
Inspected main relief valves, cleaned anD put back in.
Cant really figure out what next …
Can anyone add anything ?🫡
Have you checked servo filters in the hose line to the levers P ports on the underside of the levers
