Spurry
Some avant action this morning. Took longer to get there than do the job 🤪. 15x 1t bags moved round this morning...bag lifter is deffo better than using forks.
View attachment 82067View attachment 82068
I guess one of the main benefits is that you only have to get out of the cab once to hook the loops on. It's always a bit iffy to get two loops on each fork at once, or even worse if there are no loops at all. Nevertheless there is little to beat the Avant. 😉
It's even better than that, I had an assistant to hook them on. 🤪
I was more meaning it's better than the forks because of it keeping the loader arm lower and tucking the bag into the machine, it makes it alot nicer when negotiating the terrain
Been a while since I had the trencher out. Finished off one of those jobs where you seem to have every attachment on it.
Then it was on the road..
Find the JCB I’d forgotten about (57 days since I used it last according to the tracker on the key)
And get the skid steer into the job I actually bought it for. It’s ideal on the banks.
Busy few days fixing drains, 350m2 asphalt, and kitchen going in at home and leds getting sorted etc
I am no longer an operator- just a mere seat filler. 🫣
Why? I have taken the time to google how to use the float setting on the T450. It’s bliss with the clamshell bucket. A monkey could fill it. Easy to backblade on the way back up the hill also. I was worried 6’ would be too much but it’s perfect for this application. I still prefer the normal bucket for aggregate etc though- can see the cutting edge and it’s much easier to control. The spill guard on the clamshell is handy in this application though.
I’ve put the door back on (too dusty yesterday!) turned on the air con and started to use the seat belt to give my calves a rest from stopping me going through the windscreen down the hill. Even adjusted the joystick position. It’s a brilliant place to spend a shift. So efficient. More people should try these machines.
I’ve put the door back on (too dusty yesterday!) turned on the air con and started to use the seat belt to give my calves a rest from stopping me going through the windscreen down the hill. Even adjusted the joystick position. It’s a brilliant place to spend a shift. So efficient. More people should try these machines. View attachment 82111
Yanks would laugh 😂
I’ve put the door back on (too dusty yesterday!) turned on the air con and started to use the seat belt to give my calves a rest from stopping me going through the windscreen down the hill. Even adjusted the joystick position. It’s a brilliant place to spend a shift. So efficient. More people should try these machines. View attachment 82111View attachment 82112
I wanted 1 before the Avant but could only find 1 CTL think was a Gehl and the dealer never replied
I think as doobin demonstrates they are 2 completely different machines for different jobs. The ctl will outdig the Avant but won't half make a mess of the ground.
Also I don't know about avants but ctl running costs are eye watering. Ours runs on tarmac all the time so it's worse but tracks last 500hrs. And apparently 2000hrs is good going. And the lack of visibility makes me wince on a tight site.
Yeah tbf we are on hard ground a lot of the time and don't regret the Avant purchase 1 bit
Why are you running tracks on tarmac? Our test machines are on soil almost all the time and we see around 2000 hrs out of a set of tracks despite them getting a hammering on some of the test cycles. How much mess you make of the ground depends on how you set the job up and how you operate the machine.
