Hose mounting for the rotate:
A bracket is permanently mounted onto the machine, with a locking pin allowing the cross-line relief valve assembly to be quickly installed or removed while keeping the hose routing neat and tidy.
Overall, I’m really pleased with how the geometry has worked out, and the belt drive helps keep everything compact by stopping the motor from hanging out the back.
If your motor is turning quick enough at 20lpm on the 2nd aux, and has the torque to work properly, then patent it quick!Hose mounting for the rotate:
Every mainstream brand needs to be running at 50l/min on those size machines.
