Where to fix a leica laser level
hole.digger
hole.digger
Hi
I bought a leica rugby 820 dual grade laser in 2018. Cost 2400 🫣
It has been well minded.
Recently it stopped working and i sent back to the dealer and they told me the vials inside were damaged and lieca does not make them parts anymore.
Does anyone know a repair company that can fix the likes of this with 2nd hand or spurious parts?
Hi
@Laser Levels Online is a member here and seem to know their stuff ..... would think they'd be a very good bet for a try
Maxus
These people fixed my leica rugby 680, I only had a bearing go so it was a fairly easy fix thankfully. They might be worth a try?
I was also recently in touch with:
The chap there (Lee) who was pretty helpful over the phone advising me on all things laser levels, could be worth a chat?
I use them And they've previously rebuilt my Topcon DS
Also try PQS.
I've heard that before about leica discontinuing support for later products, shame, but another reason i'm not a red box.
That's why I bought the DS as well. Apart from the repeated reports of leica not liking bad weather and the huge premium. You can still buy the ds in blue so I reasoned spare parts availability will carry on for a good while.
Silversabre
Silversabre
Yes The sokkia is think is the CX.
I've used a PS hated it and had a GT on hire on a job monitoring and sounded like a group of angry wasps, I heard the motor didn't last long or at least on the early one.
Everything you get a standard with topcon or did with my DS when new...is an extra with leica. The controller fc5000 doesn't like the wet either and the keyboards don't last.
An engineer I've worked with has gt. The motors are warrantied to 5 years and are practically guaranteed to fail within that time frame so it's essential foc motors albeit inconvenient. But if you get a free calibration within that then probably acceptable.
I think the top con is great I don't get to use mine nearly as often as I would like due to a change in job. Alot of the American reviews I read really slated them for usability. But I find it really intuitive. I only had like a half hour demo. Probably can't get more than a 10th of the functionality out of it but works for what I do.
On the other hand top con laser levels are not great, or at least the receivers. Far to small a window on them in comparison to spectra or leica.
Silversabre
Silversabre
Yes I loved how simple it was to navigate through and start.
I think the American (land surveyors) prefer either leica or trimble TS's think a few use Topcon, stakeout, (construction) it's more popular.
The controllers and wet weather are the issue. In the US alot use secondary controllers like Carlson.
Laser receivers have improved I think they have a mm one, but I have a spectra for my topcon laser
Yes the Americans also can't get their heads round being able to set out without a surveying degree. The idea that we kind of just plonk a building roughly where we feel like is foreign to them. I think it requires far more calculations to reach initial setting out location and therefore they want it all done in the controller.
They take everything very seriously about surveying and setting out.
Silversabre
Silversabre
Yes need to be licensed for the state, both in Canada and the US to set out boundaries and property/plot relative to the boundaries.
Stakeout can out be done using there marks only.
But they also have monuments set...iron rods at intersections, but suffer from pin cushions where others add ther own based on there calculations and can cause issue.
The monuments are legally covered and any works that damage them need a licenses surveyor to reinstate them.
hole.digger
hole.digger
Thanks for the few suggestions made, i will get on the phone to them over the next couple of days.
Since i am without a laser i went and bought a topcon rlh5 to keep me going. We will see how it compares to the leica. But first impressions are it turns on and levels itself much quicker than the leica. The carry case is abit smaller aswell. It always annoyed me how massive the carry case is on a relatively small tool 😂
Spurry
Highly recommended too. Purchased my Spectra from there.
