Engcon EC206 (5/6ton)
Management
I think with svab it’s completely adaptable, but yes it will plug and play straight into another jcb! Just needs power taking from somewhere. Real easy fit , I’ve even labelled stuff 🤠 Aiden may confirm? @CPS
Pretty sure as long as your valve block has two pin solenoids for the aux lines your all good.. 2 x 2pin deutch plugs and a power supply were the only bits that actually plugged into the machine.
so it was being fed by your twin aux feeds? :unsure:
No single but they are double acting so I assume one solenoid was for single and other for double.. no idea
should only need a single acting supply - the tilty does the rest with its, (dare I say it?), prop Cetops :rolleyes:
Management
Yeah that’s correct, but for whatever reason it had two plugs, I think maybe it took out(switched off) the ability to use the double acting aspect of the hammer lines. No idea tbh, I never used the machine before it had the Engcon fit and I’ve only had a play with it since removing it. But you can switch between the hammer lines being single or double acting on the keypad.
Agreed I'm sure it's just gone crazy unless on a deal. Prefer true Italian style myself. But nothings cheap. KFC with 3 kids is over 50 quid!
so a dedicated loom for your Jake :cool::cool:
No, just fitted by someone that knew what they were doing😉
The SVAB system will be very "adaptable"
So basically Daves machine was set up well, the Svab system will control the main spool in double acting when the Tiltrotator is disconnected. Probably from the tilt roller.
I dont have a huge knowledge of the SVAB system, but for example, Rototilt ICS system automatically switches so that the tilt roller does the hammer lines when the boom cable is disconnected, also the rotation lines if fitted and set up too
Management
Correct. When unplugged you just popped hammer on and used any of the tilt/rotate toggles to operate the breaker without having to mess with anything else 👍🏼
