Engcon EC206 (5/6ton)
SOLD
Here it goes… swapping up to a 9ton and sold my machine without even trying, new owner has no requirement for a tilty so it will be parting ways!
Brief spec 2016 EC206, S40 , 1300 unit hours approx(always dropped off for hammer work and bulk digging), single line flow/return SVAB controls/joystick.
pickup pins on top(you’ll need a S40 Top hitch(@CPS can sort you one one to suit your machine) £6000 plus vat.
(Available end of March, still in use until then so any trial welcome)
I’ll also have forsale S40 Genuine Engcon buckets -
300mm - £300 .
600mm - £450
900mm - £600
(£1200 for all 3)
All with teeth and toe plate welded underneath. (Wont be available until new machine arrives in May ish)
olly should of bought the lot ! and fancy taking the tilty off it 🤦
unless he has one ?
Wouldn't it have been better to sell it all as a package?
Makes no odds to me, my digger is going to a tenant of mine so it’s a easy transaction.. I can pallet up the Engcon and ship anywhere in the world if needs be. Money is in the digger, and I can px the Engcon toward the new one if needs be
Maybe priced too high? Thoughts welcome before I put it on Facebook and get abused 😂
what about the proportional flow control/bypass valve from the service supplying the tilty Dave?
The what what?
somewhere there'll be a proportional valve which takes its feed from (presumably) your breaker circuit and supplies oil (proportionally) to your tilty, controlled by the DC2(?) controller, in tandem with your rollers - as demand is called for, for a function to operate, by your rollers, that valve will supply oil to the tilty in proportion to demand - two functions will demand more supply and is split proportionally by the prop. Cetops :)oops::ROFLMAO::ROFLMAO:) in the tilty head
The two little deutch plugs on the middle coil of cables goes straight into the valve block solenoids, no messing with additional divertor valves etc.
