How about an actuator fitted with a remote plug (accessible from outside the bonnet) that you power from a 12v jump pack?
same thing went through my mind DanHow about an actuator fitted with a remote plug (accessible from outside the bonnet) that you power from a 12v jump pack?
In Habit of starting my lectric ones trigger on otherwise blows fuse??actually had a decent-ish day yesterday and got to try the new Hyundai pressure washer, after I'd filled it with some lube and fuel
great bit of kit .. only annoying bit is doesn't seem to have a dump valve and have to have the trigger open starting it (can see a mod in the offing)
rotating 'turbo' nozzle sure rips weeds out of tarmac and rounds up the moss and tish in some order ...
looked great this morning after it'd dried off ......
'fore it lashed it down again at noon
we had everything yesterday .. blue sky, sunshine, rain, hail, sleet, snow - only thing missing was the fog we've had all week
that nozzle is actually the turbo, but the camera's shutter only catches it as a single stationary jet.....
Pam was well impressed with 4000psi's ability to 'shovel sh1t'![]()
My Steam Cleaner on a 13amp plug would do that. Advice was to put a 16amp blue plug on it and spur a blue socket direct off the 32amp ring for it :-( I compromised and added some 5 amp fuse wire to the 13amp fuse, That is now an 18amp fuse right?In Habit of starting my lectric ones trigger on otherwise blows fuse??
European stuff that's designed for a 16a outlet usually does. Yes but a commando won't stop it blowing a pathetic rcboMy Steam Cleaner on a 13amp plug would do that. Advice was to put a 16amp blue plug on it and spur a blue socket direct off the 32amp ring for it :-( I compromised and added some 5 amp fuse wire to the 13amp fuse, That is now an 18amp fuse right?
What rating is fag packet foil?My Steam Cleaner on a 13amp plug would do that. Advice was to put a 16amp blue plug on it and spur a blue socket direct off the 32amp ring for it :-( I compromised and added some 5 amp fuse wire to the 13amp fuse, That is now an 18amp fuse right?
More than 13a if rolled tightly but less than a cut down 6in nail.What rating is fag packet foil?
About the same as old kit kat wrappings..What rating is fag packet foil?
that block saw of Rio's was 8A running 16A start load so would kill a conventional 13A everytime ... unless it had a bit of 1" x 6mm rod in the plugMy Steam Cleaner on a 13amp plug would do that. Advice was to put a 16amp blue plug on it and spur a blue socket direct off the 32amp ring for it :-( I compromised and added some 5 amp fuse wire to the 13amp fuse, That is now an 18amp fuse right?
@V8Druid . Changing the subject, but when you mentioned you like to electrically isolate the Drema... It reminded me of a conversation I had recently. I sold an old work van to a mechanic friend of mine. It had a habit of draining the battery, and as its an older model with a single battery, he fitted one of these units. Says its worked really well. I might try one on the big compressor as that likes to not hold a charge, and its a PITA to jump as the battery is bolted up tight under the petrol tank :-/ Might be worth seeing if a 24v one exists ?
You need the little live for the switch though ?View attachment 80599 24v jobbie - only issue is you still have a circuit live in the unit - could put a small toggle/pb/key switch in to isolate that
12V/24V 240A Remote Kill Switch for Car, Remote Battery Disconnect Switch New | eBay UK
Switch rated current 240A. Automatic alarm of defective threshold and automatic battery disconnect. Loss of power delay 60 seconds alarm 120 seconds automatic disconnect. 120 seconds to automatically disconnect the device to protect the battery.www.ebay.co.uk
yes but could isolate it for when the old girl is stood - activate it to enable the remote unit - the magnetic hold will be for the NC position - the 3ma draw will be the receiver circuit -- just don't like any live circuits at all when stood/away from the old girlYou need the little live for the switch though ?
have had a pretty sh1t couple of daysI average two full body scan MRIs a year Dave ... they've already found a Schwanoma tumour on my conus, that has no indications, (as yet, well almost none) of being there/any issues ... 99% are benign apparently - op to remove it is a 50/50 on being able to walk after it ... carry on 'til I can't/it gives problems
.... pretty sure they'd have spotted anything else too
That's craphave had a pretty sh1t couple of days
laid on the sofa Sunday morning while Pam did my 'Hamster juice' infusion .. all pretty normal ... she's done it for 13-14 years now
went to get up when we'd finished and couldn't feel my left buttock, back of my upper leg, heel, underside of my foot's outer edge, bum and the rest of the 'tackle'
thought I'd trapped a nerve and it'd 'walk off' - no pain, just dead enough to stick pins in it
that was two o'clock ... was the same going to bed .. couldn't sleep as the Schwanoma is racing round in the back of my head, so got back up and spent a couple of hours on trusted med. sites reading, like the British Assoc. of Spinal Surgeons and the like.
could find plenty of references to numb buttocks, in relation to the sciatic nerve, which come with associated pain, but only one involving the rest of the numb bits and no pain and it said get help - fast.
emailed my consultants in Caerrrdiff Monday morning, filling them in on all the details and got a response about half four - seek help at your nearest A&E - soon!
should've gone Monday evening, but time was pushing on, so was there by eleven on Tuesday morning, with a packed bag, in case I ended up admitted ... but oh what a ****in' performance!!!
place was packed ... got booked in waited an hour or more to get triaged, on the most uncomfortable seats ever created.
explained the issue to a pretty little Indian nurse, who'd got no idea WTF I was saying and said I needed MRI-ing urgently- she went through the motions with the Obs. and then got sat back in the 'cattle ring'
four o'clock, I get to see 'a doctor' who spoke at mach two, had never heard of a Schwanoma tumour, or the fact I needed an MRI to see WTF was going on with my spinal cord ... in fact I don't think he even believed me about the numbness. then got sat back in waiting area, with a promise of trying to arrange a slot for me for a scan.
six o'clock and I get seen by a.n.other 'doctor' - pretty much on a par with the first, but did seem to listen a little about an MRI being the only way to suss the issue. Both of their physical exams were cursory, at best
get sat back in the 'cattle ring' - he re-appears gone seven and says he has a slot for me at 19.50 for a scan ......... which came and went
Nine PM another one calls me in - post shift change, so I have to go through it all for the third time - we'd been sat there for ten hours by now!! (and it had quietened down a bit)
"WTF happened to my 19.50 scan slot? "
" 19.50?? not possible ... MRI only operates from ten am, 'til eight pm "
" So I've been lied to twice today then? "
" can't comment, but I will ensure my colleague who takes over from me in the morning will organise it for you "
" so I have to sit in your waiting area all night - I've been here since 11.00am this morning - I might as well go home, get some sleep and return first thing? "
" if you do that I'll book you out of the hospital and you will have to go through the whole process again and TBH we'll not be able to do a lot for you as we don't have a neurosurgery dept. and it has to be life threatening before we'd send you off up to Birmingham's "
" didn't say I was going to, but it would seem to be a sensible thing to do .. those seats out there are the devil's creations - there're loads of gurneys out in the corridor - I'll get my head down on one of those - I need a scan for my neurosurgery consultant in Caerrdif , to see if the issue is what we think it is "
Pam was by now ultra PO-ed when I explained the score and I said **** it - we're going home - come back in the morning, but not before I'd had a sarnie - had had half a pint of water and sod all to eat ALL day -been labelled as 'nil by mouth' in anticipation of a scan that never happened - I was bloody starving
we were in Tescos at half eleven getting some milk and in bed, totally buggered by half twelve ...
up early this morning and rang MRI bookings clerk at nine - no answer - ditto 09.30 - was about to ring again at 09.50 and they're ringing me-
" we can do you a slot at 10.45, 13.45 or 15.45 "
" 13.45 please, see you at half one "
so the last guy I saw actually came good on his promise
went through the issues with the radiologist - again - and he said you're booked for a full spinal scan - asked him if there was any way he could share the results with the consultant in Caerrdiff - nope - would have to get A&E to do that
All great ppl in the dept. - gave me a blanket, 'cos it gets 'kin cold in 'the tube' when you'm in there an hour - three o'clock we're down in the concourse's coffee shop having coffee and more sarnies, then trolled back to A&E - totally different set of day staff to the previous day and thin on the ground - eventually managed to collar an NA to take a look at the screens, see if the results'd come down from the MRI suite - couldn't even find me on the systemwhich didn't appear to cope with more than 23hrs and 59 minutes -
" look for me yesterday - I booked in at 11.00 and was still sat here at 23.00 last night "
" yoo wer boooked out at 23.20 last night - you will have to book in again "(last twat/bloke had booked me out)
" who by - I certainly didn't ?? (porky warning) - I've been here all night "
NA would not have it -
wouldn't (or couldn't) tell me/see if the MRI results had come down or not
I 'calmly' lost it - told her I give up and would deal with someone more senior and left - ****in' tamping
Pam had already had a tits-full and gone and sat in the car - couldn't stand any more time on their seats and they certainly didn't do my numb left and not so numb right side of my bum any good - pretty damned uncomfortable tonight, even though the outer layers of me are numb, the muscles underneath aren't and complaining bitterly - hence the time stamp -can't sleep, although I'm bollo-ed
will email Caerrdiff all the info tomorrow, once i've spoken with the lovely girl on the MRI bookings desk in the morning, to get some names and let the consultant neurosurgeon tackle, getting the scan results shared - she'll have way more clout than me.
Herefords performance yesterday/ today was desperately disappointing, after last July's outstanding care
the big issue is, the longer I'm numb, the greater the chance of permanent nerve damage, so time is of the essence![]()
it is certainly getting worse for sureThat's craphope you get sorted asap
Might be worth biting the bullet and going private asap. I'm sorry but imo the NHS done for.
My dad definitely survived a huge amount longer due to not relying on NHS.
