Found an old local newspaper in really good shape earlier, from 1994.
Labourer’s wages were a bit behind where they are now!
grafting my arse off, keeping a dozen blokes 'gainfully employed', back then :rolleyes:
Riding round in circles on the weekends hoping to be Doohan and just about to start on for a drainage firm during the week hoping to be financialy wealthy neither become a reality 😂
One for the northern lads.
wouldn't have fancied been a scaff in winter on that!
if anyone wants to see the pix and ain't on linked in let me know and I'll pop 'em in here ...... looks 'kin cool :oops::oops::oops: (in the white shite sense) :(
Marko
Marko
So i don't know if this is the right spot to advertise these, however i have to say that i am proud to have made something like this. Quick run-down, these have a capacity of 6m3 and weigh in at 720ish kg. On this type of container the floor is 5 - 6mm thick depending on customer requirements, tho it can be thicker if required, sides are 3 - 4mm. Proven lifespan of a single unit is 3 - 5 years of everyday use. So what do you think, is there a market in the UK for these?
would be very much subject to price @Marko ? look well made - bottom ribbing might cause issues when emptying though ... most I've seen 'round here have flat bottoms ?
Marko
Marko
Right now they are around 2000e, tho as said price depends on the amount ordered, however i'm working on streamlining the production process to speed up production. I'm also looking at buying a robotic welding plant to reduce the price further, tho it won't be a lot cheaper. The bottom ribbing is there to make moving them around with a forklift/telehandler easier and adding a sort of guard to prevent the skip from sliping off the side of the forks while also reducing the risk of puncturing the sides and generally reinforcing the sides. As for the emptying, it does not clip anything while unloading, tried and tested.
It's not a market im in, but the price sounds quite high
@JD450A will know more
