Yep. Does look like it's on the pissLooks a little wonky to be able to spend too long on
Is that rain or water table ?It's a big hole came in this morning 7 to 800mm of water in there going to be a battle this 1View attachment 77682
2 bloody land drains 🫣Is that rain or water table ?
Client wanted to use those metal edges between a shingle drive and grass. Used the premium Corten ones. I found them a pain when trying to radius. Rusted up nice though!!Finishing off 115m of lawn edging yesterday, came up 75cm shortPriced the job well enough to not mind though , and every visit there tends to lead to more work for a genuinely nice couple
Got a 'call out' for the Defender this afternoon- our barn landlady was having a delivery of logs (I've got no logs to sell this year). The guy had driven his (very smart) iveco flatbed with hiab next to the log shed, on grass and inevitably got stuck. I would have thought hard before taking a trailer behind the defender there today, felt very soft/damp, never mind a 2wd truck with a crane and 8 dumpys of logs on! Low range, diff lock, straight out
he's left a bit of a mess behind but no ruts fortunately- he didn't have the traction to dig himself in
no pictures unfortunately
Is that your treatment plant going in ?2 bloody land drains 🫣
These are just the thin powder coated ones, not much radiusing to do here really but on a previous job with more curves they worked wellClient wanted to use those metal edges between a shingle drive and grass. Used the premium Corten ones. I found them a pain when trying to radius. Rusted up nice though!!
Depends how thick they are.Client wanted to use those metal edges between a shingle drive and grass. Used the premium Corten ones. I found them a pain when trying to radius. Rusted up nice though!!
Yes hopefully Friday fingers xIs that your treatment plant going in ?
TidyIt's not a pretty dig turns out 3 land drains 1 about 2.5m down, looking at the ground possibility built up years ago.
Ended up putting a layer of clean stone under the concrete.
Need to speak to the client as I think they will need to put a sump and pump in
Edit 1.5 not 2.5mIt's not a pretty dig turns out 3 land drains 1 about 2.5m down, looking at the ground possibility built up years ago.
Concrete surround but a lot of water constantly running. Will speak to the client in the morning they seem pretty decent so hopefully we can get a sump pump in thereTidy
Can you divert the drains or isn't it feasible?
Was called out to look at an onion that had bobbed out of ground, they had dug through drains , put unit in in gravel and not done anything with them, they were at a high level compared to bottom of dig.
How deep are those steels going in? When I was working on a Barrets site about 25 years ago we were building all the retaining walls out of timber posts like that. Stupid idea in hindsight.A few recent purchases making life oh so easy.
This Milwaukee gear is just savagely good. And its nice to use the new trailer- it’s been out on hire half a dozen times also.
The footings were wider than I’d hoped but luckily managed to bash through them by pecking an inch or so the 20kg breaker then augering! Luckily the mix was only strong in places much of it just came out with the auger. I really should get a rock bit…
Niv comp making life super easy setting out the sleeper supports and the bottle of 15% gas I keep meant I could weld with the little welder off the domestic supply rather than take the generator. All these little bits add up to make life simple.
Even got the big mixer out- so easy to use. Like a cat on a leash behind the pickup though🫣
View attachment 77717View attachment 77718View attachment 77719View attachment 77720View attachment 77721View attachment 77722View attachment 77723
Chuck a 9” perf pipe in the corner where your pump is.. can just drop a pump in. backfill the whole thing with dry mix! And fill the thing with water! (Without teaching you to suck eggs!!)Concrete surround but a lot of water constantly running. Will speak to the client in the morning they seem pretty decent so hopefully we can get a sump pump in there
I nearly said the same but didn't cos of the suck eggs thing, also if perfed twinwall or whatever is down to aggs in bottom in the sump hole it acts as decompression.Chuck a 9” perf pipe in the corner where your pump is.. can just drop a pump in. backfill the whole thing with dry mix! And fill the thing with water! (Without teaching you to suck eggs!!)
