Shoring....
Danny
Danny
Step and batter back the excavation if the customer wants the job doing the grass will grow back 😁😁😁😁
You can hire light weight manhole boxes same strength just light weight may be an option
Not a option to batter back :( due to mess.
Issue with the boxes is extracating them as we pour the concrete due to them being stacked.
K
Komatsu
Is it me or does anyone else think that it’s a bit of a strange coincidence that day before yesterday Rory is asking about shoring and yesterday there was an earthquake down his neck of the woods🤔😂
Management
Yomm
Pump maintenance
Electric bills
Needs to be big enough for 24 hrs or more if power failure
A lot of long term costs over simple gravity fed tank
[/Q
Pump maintenance
Electric bills
Agreed, but the same costs and maintenance will be associated with the treatment tank anyway so can all be done with the annual service.
Best suggestion yet is batter it all back (if there is room) - pumping chamber would be a fudge imho
Yep, but alas no.
There is room, but customer does'nt like mess.... I've already turned some of his lawn (about a 5%) into a ploughed field, so I don't think he would appreciate the loss of another 10% :confused: despite it being the best solution.
This is a case of making a job fit the customers unreal expectations. Making mess vs making the job as safe as possible....no brainer really. If customer doesnt understand that then bugger them and let next mug do it.
Two options with two prices - let the cuntstomer decide.
What size/shape of tank are you putting in. Is there a chance of digging hole putting manhole rings in as shoring then putting tank in middle. Conc between tank and rings and then backfill just leave rings in.
Tanks nion 10' wide, so rings will be too heavy to handle
Yeah I see that now after looking back through page. If you can't get away with battering back piles must surely be you're only then.
Left hooker
Left hooker
Did a job years ago for tank 4m deep sheet piles and hydraulic beams like in Lynch's vid but instead of driving the sheets down we dug around edges first with 18" bucket dropped sheets down back filled set up beams placed one on top of other with top one hooked over top of sheets and lower one chained to one above
Excavated out till top one can't drop anymore pumped it out until solid then dig down till lower one maxed out on chains the pump out to secure it then dig to desired depth of excavation
Did it with my 4.5 hitachi at the time they did get a 7 ton in to dig it but couldn't get the depth my machine had better reach so stayed to do the job only just lifted tank in with it mind 😂 as we filled with concrete we took lower beams out then upper ones then the sheets while concrete was still soft and liquid
Just to wrap this up. Should in theory come in at under £2000, for the gear to do the job properly.... Cheap in my opinion.... probably not in the clients opinion. (y)
