groundworker
Yeah was very happy to have proper controls, night and day difference in comfort and productivity for me.
Fair play. Not something I would take on!!Fun and games this week.
First time using one of these Bobcats, brilliant machine. Wouldn't have been able to do it without the extra width on the tracks allowing me to straddle the trench.
Agreed, when we have done stuff like that I haven’t taken out the whole back of a building and dug around props that closeFair play. Not something I would take on!!
Good work by all partiesAgreed, when we have done stuff like that I haven’t taken out the whole back of a building and dug around props that closealways knocked out pockets where the new founds run through etc, then built up as much as possible before knocking everything out.
Top class propping though i must say!
The builder has done all the propping to a temp works design he had done. We did the demo as his guys were busy and we could get it done quicker with my dumper.Agreed, when we have done stuff like that I haven’t taken out the whole back of a building and dug around props that closealways knocked out pockets where the new founds run through etc, then built up as much as possible before knocking everything out.
When I propped my gable end I didn’t have enough needles so use a forklift fork for one of the holes…Yeah strong boys are not the thing for propping like that, they flex something terrible! . We pin everything and just use the odd strong boy for any loose bricks as you go. I’ve got a pile of 100mm box section cut at 1.5m lenghts they work a treat!
Prop palThere those new props I’ve seen advertised the blue needles? What they called?
Did you use the other fork to lift the steel in withWhen I propped my gable end I didn’t have enough needles so use a forklift fork for one of the holes…
Unlike my suprisingly uncomfortable jerky thing to spend a shift onYes, I love mine and wouldn't change it- as anything else on servos is wider. It's seven years old now but only on around 600 hours.
A surpisingly comfortable machine to spend a full shift on.
I have an sv08, I think its great, especially as its so narrow. Done so many jobs where its been touching both sides of the alleyway/gateway so even a 20mm wider machine wouldn't fit. Did a job earlier in the year where we pallet trucked it through a printworks, up in a goods lift and out onto the roofUnlike my suprisingly uncomfortable jerky thing to spend a shift ondoes the job when necessary though.
@tinydigger (Andy Smith who's been MIA for a whileI have an sv08, I think its great, especially as its so narrow. Done so many jobs where its been touching both sides of the alleyway/gateway so even a 20mm wider machine wouldn't fit. Did a job earlier in the year where we pallet trucked it through a printworks, up in a goods lift and out onto the roof
I'd certainly wouldnt call it comfortable but I've no real complaint, even though it looks comically small underneath me.
Long term plan is to upgrade to an E10 or similar for normal micro jobs, but keep the sv08 for the really tight stuff.![]()
Hope he's OK he did have some health issues iirc?
last I heard, he had lost several stone and was doing well (but I believe he and his partner/wife had also split up ??).. not heard from Andy in ages - can't find him on FB either (were 'friends' but his a/c has vanished)Hope he's OK he did have some health issues iirc?
I had exactly the same when I changed the engine in mine, turned an easy job into a ball ache. Crap designUnnecessary faff from bolts with no room for a ring spanner, rounding off as soon look at them with an open end. Just about managed to knock a quater inch socket on them luckily.
Obviously I only thought to change them for Allen headed just as I'd nipped the last one![]()
Slanetrac dumper engine been giving greif on a hire job- I suspect it may have been on its side at some point...
Pulled the part fitted Loncin out of the Ransomes Mg5 to get the Slanetrac back working ASAP. To useful to leave sitting about.
reassuring to hear that i wasnt just being a plankI had exactly the same when I changed the engine in mine, turned an easy job into a ball ache. Crap desig
