Very true - the first year is the hardestwe just aren't used to it and it's always in with a bang and gone again - no time to acclimatise
Ditto - windows and doors open at night/evening. Then shut during the heat of the day. Loads of fans deployed.still got two 12" going, circulating the air in the house - doors wide open and the windows - proper glass thermometer outside on the wall says 23C and the c/heating thermo says 22.8C .. gonna be a warm night![]()
it wasstill got two 12" going, circulating the air in the house - doors wide open and the windows - proper glass thermometer outside on the wall says 23C and the c/heating thermo says 22.8C .. gonna be a warm night![]()
Thanks gra ,been woken about 3.15ish twice ,that's what it isit was--
was 20C outside at 04.00 -
finally sussed WTF keeps waking me up at 3ish most nights, as was awake when the bar stewards came over --
three planes -
commercials by the sound of 'em -
in quick succession (couple of minutes apart).
'Nother one at 4 - even Squeak looked up to see WTF the noise was ?![]()
Yes you run it in reverse.Can air sourse be used to cool houses, think I read it somewhere
So what the feckers up toThanks gra ,been woken about 3.15ish twice ,that's what it is
louder and a lot lower than usual - presumably climbing?Thanks gra ,been woken about 3.15ish twice ,that's what it is
who knows ..... but explain this one to me yesterday afternoon - on, then off, trail - headed Bob's wayAre they cloud seeding in the middle of the nighttime now?![]()
a damned good questionSo what the feckers up to![]()
that's cool .... one over at the right time, but not three .. and the other just after 4 ...... loads headed east 4.30 on
Big difference between an air source heat pump boiler and an A/C unit thoughOur aircon does hot and cold![]()
Yea, I’m half considering air source heat on the next new builds , oil boilers are a faf and no one around here installs them anymoreBig difference between an air source heat pump boiler and an A/C unit though![]()
If its Air to Air (A2A) then yes usually easy to run both ways. If its Air to Water then not possible unless the system designed that way, I have yet to come across a UK system built for cooling, but I expect to see it more in the future. Condensation can them become your enemy if using air to water to cool. We have Air Con in the office.. and its lovelyYes you run it in reverse.
must to be air to air my folks haveIf its Air to Air (A2A) then yes usually easy to run both ways. If its Air to Water then not possible unless the system designed that way, I have yet to come across a UK system built for cooling, but I expect to see it more in the future. Condensation can them become your enemy if using air to water to cool. We have Air Con in the office.. and its lovely![]()
bloody planesit was--
three planes -
