Brake pad light was on so had new pads fitted - was worn on one side much worse than other but calipers were fine. today it got hot on one side but not on the other, hard to diagnose as 90% of tile is fine, sees to coincide with a quietish noise in cab that is silenced when you activate park lightly, strange one,I'm guessing there is a leak that is causing pad to engage a bit, but doesn't struggle to keep air up.
Anyone come across this? Suppose it will be a case of finding when it splits to a side and checking from there back, not much idea when it comes to truck brake circuits.
