You can get the multi size any material to mdpe. Expensive but a pretty good insurance to keep in the van.
Rumor has it you can get them for gas as well.
Plasson utc are a handy get you out of trouble fitting 🙌🏻
A red phone box and an old Jag...subtle hint he's an ex pat 🤣🤣🤣
Yep nice bloke but shameless old school ex pat, one of the first i guess , been here 30 years and first thing he did was put a phone box up ! Expats are as a rule harder to spot nowadays in fact round here at least most have gone back the other way, i suspect it's same all round eu.
24 hours into a powercut here. Starting to be annoying now. We are okay with LPG fire and Hob along with cordless lights and USB adaptor from van. Most of the village buggered, no one’s prepared these days. Keep having to take thermos / hot water bottles up to the old chap round the corner as he’s more or less chair bound.
Annoying thing is most of Cornwalls power supply passes over head through edge of village and that’s fine.
I foresee a rush on camping stoves and LPG cabinet heaters next week 🤣
small suitcase genny is sufficient to run 99% of gas/oil fired boilers and a light or two/fridge ...
IIRC all boilers are 'sposed to be on a 13A plug :giggle: ...
I keep a lil' 2.2kva Hodna specifically for such events and run a 9" grinder/big hammer drill at any distance from a power source ;)
If it's gonna be off for more than an hour or two, I'm on SSE's priority list (usually got £10+k's worth of meds in the fridge) - ring them and they turn up with a genny and couple me up (y):cool:
heat pump - you'm ****ed :(
Some rather anxious leccy car owners I bet.
To think us fossils with a few jerry cans of derv can crack on😂
Wouldn’t take a lot to switch my boiler over to a 3pin plug but can’t really be arsed, gas fire keeps us warm. Might look into a proper changeover switch.
Fitted one in my first place and never used it 🤣.
Of course you can always just use a good old fashioned death plug 🤣
three matchsticks ? :ROFLMAO:
could always use the good ol' RS quick connector
13A changeover plug's as good as you'll need ;):giggle: .... odds on you'll have to run a lead to it from a genny anyway :rolleyes:
The propane cabinet style heaters are always handy to have somewhere in a shed etc, used to have one in my first flat that had economy 7 night heaters that where crap, few minutes and room be toasty if a wet heat.
never seen a propane one, but got three butane ones sat in a box .. light one occasionally when it's 'kin cold in there .. t'others're handy standbys :rolleyes:;) in case
One of those Chinese diesel heaters wouldn't be to bad either. Build it into a large amount box and run of whatever battery you have lying around either car or power tool
