How can anyone sue for driving through a space that’s too narrow 😂
It wasn't even to narrow, could get a transit tipper through. On a junction so had to turn into the bollards, and the council specced 600mm bollards not 1200mm but you just had to get square on before you entered. Funny thing is the you turned right into the width restriction and the drivers kept hitting the driver's side bollard. That you can see out the window. And once they hit it kept on driving and peeling the doors open
Pretty much that, sorry mate! Plus I'd done the first pickup somewhere in North Wales so was already on a tight scedule to get back to the yard before 5pm after leaving at 4am. As much as I'd have loved a cuppa and to pick your brains about removing the tilty cetops in favour of direct pipes (manifold??), I thought it best to wait until the missus and I are on holiday and chilled! Had it been just the forklift to collect I'd have come to you first for a few hours.
Whats that place maybe twenty minutes north where theres the worlds tightest bridge (apparently 7' wide but I swear it was less) over the river? Yellow steels each end. Llansomethingorother.That's a fucker with a GH1054! Good job I've got a few miles under my belt on tight lanes, I wasn't going to get a second chance at it! Very much a heart in mouth moment. Why the fk does that satnav send you that way?? Most drivers with a medium estate car would baulk at it, never mind the wide body tipper Ranger and a trailer.
Yes, it was Tredegar. I've been looking for one of those models for a long time. As small as they come, and with the right mast to work under my mezaninne and lift on top of it- at 3.3m it's an awkward lift that many small container spec fork trucks fall short on. This maxes out at 3.7m so perfect. It's old (2004) but has done 183 hours, most of those at a training school. Only 24v so not too many cells to worry about either. Fingers crossed- at £2600 it was nowhere near the bargain of £4500 for my 2017 Hyundai diesel with 550 hours, but it should be ideal for working inside, loading the mill etc. The state of charge light started at the full four bars, then down to one and the red, back up to three, before settling on 2 bars. Multimeter had it at 24.9v. I've left it on charge overnight and we shall see.
Llangynidr
you mean this one :ROFLMAO::ROFLMAO:
you obviously came at it from Bwlch, off the A40 if coming from N Wales :giggle: ...
they chicaned it after one too many BIG vehicles tried their luck, some time ago
presume you then went up over Llangynidr moor to Ebbw vale/Tredegar ... nice run ... used to be one of Top Gears fave locations for 'sporty' motors
EDIT ....... just read all the other posts :unsure::ROFLMAO::ROFLMAO:
We put in width restriction bollards to protect a listed bridge in godalming.
Set at bang on 7ft wide. Loads of other works involved so we where on site nearly 2 months with a full road closure. We took all tm away on a Saturday lunch time. An emergency highways gang where sent up by Monday lunchtime to remove the bollards as so many people had opened up there vehicles and where trying to sue. They have since been reset as a pair of traffic islands just over 7ft wide and then the bollards set back from the kerb lines so nearer 9ft wide.
Same thing happened outside Oundle, 15 miles from me. Put up during the holidays, taken down when the school buses started running again.
2 x drums give a bit of scale to this lump - tmk300 v handy today - and gripper for pulling out all the self seeded rubbish along house back.
now the rubbish is away its the nice job of shape it all up and build a bund to protect house from field run off.
16ton in and a lot of muck! Avant is a beast
Was asked to do a lead replacement water service due to a big leak on it....November's bill was £750 😱
Found the leak, someone previously had damaged it, so rammed a bit of copper pipe in each end and then denzo taped it. It lasted a while as the tar patch above looked a few years old.
View attachment 66999View attachment 67000
WTF did they just not sweat it to the copper :mad::mad:
