history of the first truck-mounted concrete mixers the first example of concrete mixer pumps:
Hi, some informed user friend, could you kindly tell us who invented the concrete mixers mounted on trucks, the first examples, the first historical manufacturers. Now they have hydraulic operation, I remember the concrete mixers with rotation of the mechanical drum, with a large toothed crown keyed on the rotating barrel, a transmission chain and a pinion that gave the rotation. Bicycle transmission type. Thanks to whoever will provide useful information
www.plant-planet.co.uk
In the Bavarian town of Memmingen, Stetter, which specialized in concrete mixing equipment early on, started the era of ready-mix concrete with the first truck-mixer. The drum has a nominal volume of only 3.5 m³. A larger drum is not allowed on biaxial chassis due to legislation in force at the
ck-mounted concrete pump
With the ABP 20, SCHWING launched the first truck-mounted concrete pump in 1965. Only two years later, the higher-powered version ABP 30 is also available with a placing boom.
dyconcretepumps.com
Brief History of Concrete Mixer Trucks
The concrete mixer is a key part of any construction site. The evolution of the concrete mixer trucks has been a continuous effort over the years and demonstrates the long journey from their original design.
1958
First Stetter truck-mixerIn the Bavarian town of Memmingen, Stetter, which specialized in concrete mixing equipment early on, started the era of ready-mix concrete with the first truck-mixer. The drum has a nominal volume of only 3.5 m³. A larger drum is not allowed on biaxial chassis due to legislation in force at the
The History of Concrete Pumps - DY Concrete Pumps
Concrete pumps boast a long history, from their manufactures, mechanisms to their latest, most innovative designs and features. Contact us to learn more.
