history of the first truck-mounted concrete mixers the first example of concrete mixer pumps:
Hi, some informed user friend, could you kindly tell us who invented the concrete mixers mounted on trucks, the first examples, the first historical manufacturers. Now they have hydraulic operation, I remember the concrete mixers with rotation of the mechanical drum, with a large toothed crown keyed on the rotating barrel, a transmission chain and a pinion that gave the rotation. Bicycle transmission type. Thanks to whoever will provide useful information
In the Bavarian town of Memmingen, Stetter, which specialized in concrete mixing equipment early on, started the era of ready-mix concrete with the first truck-mixer. The drum has a nominal volume of only 3.5 m³. A larger drum is not allowed on biaxial chassis due to legislation in force at the
ck-mounted concrete pump
With the ABP 20, SCHWING launched the first truck-mounted concrete pump in 1965. Only two years later, the higher-powered version ABP 30 is also available with a placing boom.
Brief History of Concrete Mixer Trucks
The concrete mixer is a key part of any construction site. The evolution of the concrete mixer trucks has been a continuous effort over the years and demonstrates the long journey from their original design.
www.plant-planet.co.uk
1958
First Stetter truck-mixerIn the Bavarian town of Memmingen, Stetter, which specialized in concrete mixing equipment early on, started the era of ready-mix concrete with the first truck-mixer. The drum has a nominal volume of only 3.5 m³. A larger drum is not allowed on biaxial chassis due to legislation in force at the
The History of Concrete Pumps - DY Concrete Pumps
Concrete pumps boast a long history, from their manufactures, mechanisms to their latest, most innovative designs and features. Contact us to learn more.
dyconcretepumps.com
