How heavy is the boxYes said without that box we wouldn't have gone in there, it feels safe with the box
Couldn't think of anything worse !Got dragged around Trafford centre today.. what a waste of a dry day![]()
Approx 500kg aluminium but steel strutsHow heavy is the box
but you have a great postal service in FranceThis is rural France everything is miles away apart from agri dealers![]()
M12 x 160 x 12.9 SHCS .. buy a handful and keep an eye on itView attachment 66286
Managed to get a 12mm x 140mm roll pin from local agri place to retain the King post pin ,should do for now but it ideally wants a 12mm x 160mm to get plenty in housing ..can't seem to see one online , @V8Druid bet you know where I can order one![]()
Put a bolt through ?but you have a great postal service in France
can at least see when it lets goPut a bolt through ?
much better, more reliable capture and easily seen when it fails (and stronger than a roll pin)I'd nut/bolt it personally..
Looks like it’s grown up with a load of earth tooSun shine in Devon. Managed to sneak away from the day job for a few hours. Borrowed Kubota runs the bigger auger flight like a dream. Haven’t checked the exact specs but aware that it’s overpowered for the Auger so keeping it on tickover to reduce change of buggering it.
Back later to sort a gully and French drain, and then stone up levels. Will wait for a Sunday to clean out back onto to the road. We stopped using the gateway back in early 90s and it’s grown up with blackthorn since then. Annoyingly it’s not shown on any maps or deeds, so I’m expecting some nosy neighbour to dob me in to council![]()
Not sure what model augertourque that is but my x2500 has taken some grief from 2.8t over the years. Keep expecting it to blow but it doesn'tSun shine in Devon. Managed to sneak away from the day job for a few hours. Borrowed Kubota runs the bigger auger flight like a dream. Haven’t checked the exact specs but aware that it’s overpowered for the Auger so keeping it on tickover to reduce change of buggering it.
I ahem, run a similar sized digger on the 7 tonner..... @Dr peckerNot sure what model augertourque that is but my x2500 has taken some grief from 2.8t over the years. Keep expecting it to blow but it doesn't
Yes wal partially filled in 30 years ago. Very distinctly less than original Devon banks adjacent though.Looks like it’s grown up with a load of earth too![]()
Mine is X1500 I think. Same dimensions as X2500 I believe. X1500 is rated 20-45lpm.Not sure what model augertourque that is but my x2500 has taken some grief from 2.8t over the years. Keep expecting it to blow but it doesn't
