There is options for a 4.5t tow capacity by going pickup and 5th wheel, although the cost of 5tg wheel trailers is mental.For the record, the SS1-5 which I have in my 3 ton Kubota has been a fantastic set up for me. You can tilt and rotate at the same time. Once you have it you would not want to go backwards!!
Mr Gunners is absolutely spot on with why he went DC2. The additional cost for me as a part time digger driver was not a viable option.
My problem now is a could do with a bigger digger ever now and then but don’t want to be without the tilty!! I have throughly enjoyed having the set up I have now got as it goes on a trailer behind the truck. Going bigger means I am also looking at bigger transport options and that is also another ££££ pit that I don’t want to get back into!! So for now, I will keep my head down with what I have and keep saving!!
Don't really know anything about tiltys but could you have the all dancing version in a 3t and then swap it to a smaller machine but run the more basic control system?
nah one o' these RoryIf you do get a engcon, don't forget you need a 360' hat to match![]()
that'd take some doing .... the Cetop3s in't tilty wouldn't have it ... all dancing are Prop. and constant flow ... basic are on/off with prop. flowThere is options for a 4.5t tow capacity by going pickup and 5th wheel, although the cost of 5tg wheel trailers is mental.
No, Actually that would workthat'd take some doing .... the Cetop3s in't tilty wouldn't have it ... all dancing are Prop. and constant flow ... basic are on/off with prop. flow
Really? I'm pretty sure Engon said no when I asked them but cant really remember. Lots to take in.No, Actually that would work![]()
Can't speak for engcon obviously, but it is doableRea
Well sort of... The expensive bit is the solenoids that can tolerate being driven with a PWM or duty cycle signal. Normal on/off solenoids don’t tolerate high switching cycles or so I’ve read. I had similar ideas of creating a couple of proportional lines on a digger with a CETOP block and basic solenoids but found they would be unsuitable, the reason full spec tilties are expensive is because of the specialist valves rather than the software I reckon?Yep, I have been doing some research recently on how to get proportional control hydraulics using solenoid operated valves.
It took some sussing out but was actually quite simple to achieve using an Arduino micro controller.
My application was nothing to do with tilt rotators. I don’t know how the various systems offered work but from my experience it’s totally possible to use a single acting hammer circuit to provide oil pressure to the end of the dipper and then fed that into solenoid valves controlled by say thumb wheels on the joy sticks to get a couple of proportional circuits for a tilt rotator. It would just require replacing the stick tops and running a multi core cable down the arm plus the cost of the valves.
Is this what is being done already and have I just reinvented the wheel or am
I on to something?
Rob
I on to something?
Rob
so you're saying you can run a Prop. solenoid as a simple on / off solenoid Aiden ???Can't speak for engcon obviously, but it is doable![]()
Correct Stu - As Aiden said, he can't speak for Engcon and I can't speak for RototiltMost tilty wiring down boom is flyby wire as I've in my current tilty have 4 wires plus an earth so there's a lot of things going on in the tilty for only 4 wires as I've got 3 prop valves and a hitch valve
Rea
Did stick length get talked about on your E27? I have been on the look out for a 2.5 tonner for a while and saw a nice E27 for sale and noticed it said long arm on it so are there some options on stick length and would it be best to avoid the long stick if I plan to put a tilty on it ? or isnt it as critical as on say an 8T ?
And have you had any seat time on a Kub U27 to compare to your E27 ?
Yup, the E27 I got has an extra counterweight, which is a right lump. It handles the grab and rotator extremely well, I'd imagine it would handle a tilty too.Yes it would be best to avoid the long stick, or get a slice made to counter the extra weight of the tilty.
