Making it pay.........
Engcon UK
Engcon UK
The Noble Art of Digging
No, your not going to be happy with that system, if your going to do it, do it once and do it right
I Agree, to be honest this would be a bit of a backwards step for you!!
you'd hate either /or Doob :cry: .... and not being able to rotate a grab fully :mad:
As I said earlier, Doob; my recommendation would be for the SS9 system. However, if you want a try on an SS1 to help you decide I can put you in touch with a number of users (I think Andrew also offered this).
Regy53
Regy53
I like cake
do any of you guys consider resale in your costs as a tilt rotator on a machine sells well and really can acheive great rates back if looked after.
Personally I'm planning to keep it and share it between whatever diggers I run, same as the rest of my attachments. I always assumed that you'd loose proportionally more on the tilty than the digger selling it with a machine.
Engcon UK
Engcon UK
I'll let Ross answer the question about residuals (although I do know the answer - we can't get enough 2nd hand units), but if you are planning on sharing a tilty between two or more diggers then the golden rules are:
Same weight class of diggers (this is determined by the S standard which determines hitch size)​
Same excavator hydraulics​
Same control system​
As Doob alluded to earlier, the Hyundai and the Bobcat have different hydraulic setups and the difficulty is that the only systems that will work on both diggers are either the fully proportional DC2/SS10 system or the very simple SS1 tilt or rotate unit. The former is what Ollie @Gunners has, others have the latter.
If I can depersonalize this from Doob for a moment, plenty of people try to maximize the 'bang for their buck' and share tilties. Robin Webber's 4CX does this with his son's 85Z-1 (DC2). John Clarke's Takeuchi minis do the same (SS1-5) and there are plenty of other examples. We've had a few spectacular fails as well where customers have wanted to share across different digger weights (22T and 14T, for example). We felt in this case that, whilst it may not look ideal, it could work until we found out that the smaller digger was a ZTS with a long dipper. In the end the customer took a second, correctly-sized tilty and we swapped the Frankenstein hitch that we had created to make it work. :eek:
Robert .... memory fart time ... SS9???? :unsure:
SS1 is either / or, from single prop. feed
SS10 is 4 piper? two prop. feeds
what's single prop. feed and buttons (like I've set mine up as, with everything available, selected simultaneously? )
Engcon UK
Engcon UK
s'OK Graham. It's all here https://www.planttalk.co.uk/threads/tiltrotator-selection.187/
......but the quick answer is as follows. SS1 is for diggers with a single hammer line, double acting. Rate and direction of flow is decided by the hammer pedal (or in Doob's case, the proportional roller on the joystick) and the service (tilt or rotate) by a single momentary button on the other joystick. Cheap to install, but limited. Think of it as a tilting bucket with a separate rotation function (tilting hitch meets tilty, :love:falls in love, has offspring:ROFLMAO:(y))
SS9 - digger has two factory-fitted proportional lines controlled by joystick-mounted rollers. These operate the tilt and rotate functions of the tiltrotator, but a latching function is added via a cab controller which switches the tilt function to extra1, extra2, (tiltrotator) hitch control and back to tilt. Doob's E27 has this. Perfectly serviceable, about 20% of our installations are with this, but the limitation is that you cannot operate the extra functions (including the tiltrotator hitch unless you are direct mount and have a separate hitch line) at the same time as the tilt function. This is what Ollie @Gunners deliberated over because you might not be on the flat when changing attachments or you may want to adjust the tilt angle while closing a grab:unsure:.
SS10 (DC2 for Engcon, ICS for Rototilt), single hammer line fed directly into the top manifold of the tilty and the proportional values and control systems are all in or attached to the tilty and the dedicated joysticks. The valves, joysticks, controls systems and installation time all add cost but this is the blue riband. You have full proportional control of everything independently and simultaneously. 👏
Yours is SS5. This is a non-proportional setup which uses the same principles as SS10 above, but with Non-prop CETOPS, which are a bit more affordable and you control the service and direction on the buttons, and adjust the flow on the pedal. All services (tilt, rotate, extra1, extra2, hitch) available simultaniously. Very popular on road/rail, since discontinued by us although we introduced a cut-down version of this for minidiggers which just has tilt and rotate and is called SS1-5.
HTH
K
Komatsu
It’s all thought about Ross, hence why all extras where put on my machine , making a full European factory spec with tiltrotator to attract top money. Saying that, I let my last machine go with out the tilty on. Did that for a few reasons, however, the spare tilty and hitch is getting cleaned up and getting put up for sale now as looking at getting another attachment, so no point keeping it undercover not earning its keep.
Regy53
Regy53
I like cake
I don’t think some people do think about it at times. As the cost of a tilty is a lot but they do hold a lot of residual especially if attached to a nice digger ( experience I have )
K
Komatsu
Have to agree with you at some of the systems that get put out🤔, always said that you need to look at the big picture and whats going to happen if you decide to sell up in a couple of years or your situation changes. You want something that your going to be able to sell on with relative ease, rather than trying to off-load something that no one wants. A bit like the situation we had a number of years ago when they started putting PUP hitches underneath tiltys.
was it Ollie who was going to do the same, then went full system?
SS9 - Perfectly serviceable, but the limitation is that you cannot operate the extra functions (including the tiltrotator hitch unless you are direct mount and have a separate hitch line) at the same time as the tilt function. This is what Ollie @Gunners deliberated over because you might not be on the flat when changing attachments or you may want to adjust the tilt angle while closing a grab:unsure:.
Ahh the annual discussion about tiltrotator control systems. It makes a welcome return with the same arguments as last year! 😩
I cant speak for others, we all do a variety of work on this forum and its what makes it so interesting. However, I will restate the thought process I went through as Doobin and countless others are no doubt going down the same path. After being a big supporter of the simple SS1 system I ended up going full fat, all singing all dancing, all the mod cons (whatever you want to call it) known to Engcon as DC2.
And here's why.
1. I was changing my business model from a labour based traditional groundworker to more owner operator and groundworker for hire. I didn't know if there would be enough work for a 3t digger and so wanted to make sure the machine and myself were spread nicely to cover landscaping, Arb work, farming, trial holes, as well as the traditional groundwork jobs. The DC2 system allowed me to run more attachments in the future and wouldn't pigeonhole me into one kind of work.
2. To make my vision of a one man army work, I wanted a selector grab. DC2 gave me the best option for running this all seamlessly which should aid production - something I was keen to achieve to justify the stupid rate I intended to charge.
3. My machine came with a single, double acting aux line. I wasn't about to change machine at great expense just to get a tiltrotator and the cost of putting an extra line on (to potentially run a 4 pipe system - a good compromise) was half the cost of DC2.
4. I gained a hydraulic hitch on the tilty - again, having watched hours of videos of operators using tiltrotators in the field, I could see the advantage of swapping attachments in less than 10 seconds and how that would help my productivity - again to justify the high rate. And I'm lazy🤪
5. Engcon were doing very attractive finance and this played the biggest part in going DC2. When you look at the monthly payments, they really arent crazy to go top spec and this helped me get over the hurdle of the price - because the DC2 system does nearly double the basic cost. But by god is it more than twice the system.
The ability to tilt and twist as you dig has sped up the work I do no end. I've said it before, the tiltrotator makes me 20% faster on 80% of the digging I do. And my customers love it. Its won me work, its increased my profits and I honestly don't use the shovel anymore (except when being paid my rate to dig post holes like last week😉)
All that said, I can completely see why you would go for SS1 on a mini digger below 3t. If you just did golf courses for example, the ability to use a grab isn't really much of a priority, or if you want to swap between machines, the cost of 2 DC2 systems would be eyewatering. I've driven the SS1 system, its very good, simple to get the hang of and I could see myself having no problem with it. And for 50% of the cost, its very tempting. I wouldn't have it on a machine above 3 ton as once you get above this weight, the attachments, gripper etc available to you make DC2 a must to get full use of the system. A 4 pipe is a better compromise if you have the aux lines, but for those that don't have that option, consider what you want to do, speak to owners of similar machines to yours and ideally ones that do your line of work. Everyone's happy to chat diggers - its why I'm typing this post!
just to poke the 'nest' a bit :giggle: ..... depending on the amount of use you're gonna give it and how frequently you might swap machines ... the SS5 is still a very cheap option ;)... I'm sure @TiltyShaun will agree ... as long as you have a one way (or two way) prop pedal the only additional costs per machine'd be a set of stick tops and a bit of wiring to connect them to the tilty ..... you could then have everything :cool:... tilty allowing of course, for a rotary feed through it :rolleyes:
Scandalous lie that :LOL:
For the record, the SS1-5 which I have in my 3 ton Kubota has been a fantastic set up for me. You can tilt and rotate at the same time. Once you have it you would not want to go backwards!!
Mr Gunners is absolutely spot on with why he went DC2. The additional cost for me as a part time digger driver was not a viable option.
My problem now is a could do with a bigger digger ever now and then but don’t want to be without the tilty!! I have throughly enjoyed having the set up I have now got as it goes on a trailer behind the truck. Going bigger means I am also looking at bigger transport options and that is also another ££££ pit that I don’t want to get back into!! So for now, I will keep my head down with what I have and keep saving!!
I'd look at a trying out a brand new digger of the same weight class. They put out a lot more power. Truck and trailer plus mini digger is the most profitable setup for most small jobs IMHO. You can always hire (with transport included!) a bigger machine when you really need one.
Hg2702
Hg2702
I won’t lie since the dig day there has been some serious thoughts going on here, business is changing slightly and I might be of to pastures new but should I not be there may be a few changes to a lot of things 🤣
If you do get a engcon, don't forget you need a 360' hat to match :ROFLMAO:
