needed to keep this both stiff and light -- 40 square was the minimum I considered I could get away with and maintain enough strength to be useful ... with sufficient bracing to aid that
the lateral took a bit of consideration, but ended up with this idea and stiff as....
took a bit of detailing - but got there eventually
then trial fitted it again to make sure it all still lined up and fitted as it should - it did
pins went in sweet as - with a tap :giggle:;)
rain forecast over night and it'd now gotten a bit 'heavy' to handle back into a box for the night so shot a coat of shiny tish onto it ... which wasn't a quick job ... have painted my share of lattice extensions over the years and the easiest way, is paint all you can see from one direction - roll it 90 deg.s - go again - etc., etc., 'til you can't see anything you've missed .. works well but had a torch out after tea, by the time I'd finished ...
looked ok next morning - after coming back from taking the kids to nursery/school
left the ends as there is more to do there
then I needed the bench ......
so
now had a cat head to create and a few other bits :rolleyes:
both for this and a few other things, whilst I had the plasma out ... so hauled a few bits of materials out of hiding and got lopping
stuck that carriage on the bench whilst I had the 'Drema wound up
bit of nesting practise ..
free handing the curves is far from easy with a 130A torch .... should've gotten my 80A one out, but CNBA -ed:rolleyes: ... got it done
and on to some more bits -- DRO is so easy for working to specific centres - as long as you have one axis parallel :giggle:
Tapped these tonight 'fore tea, after the kids got collected earlier than usual :rolleyes:
and was hoping for as full a day tomorrow, as the weather is likely to permit, but had a message from Russ earlier and I'm in Pontrilas after lunch/as soon as he can get back from Worcester, take down a couple of old silos we put the replacements up for a few weeks ago :rolleyes:
weekend is supposed to be absolutely atrocious -- but got some machining work to do - so all is not lost :giggle::rolleyes:
and now it's time for bed/zeds
View attachment 64652 View attachment 64651
View attachment 64649View attachment 64648
View attachment 64647View attachment 64645
ADMIN.
PLEASE MOVE THIS TO THE OOPS THREAD PLEASE? 🤣🤣🤣
left here at 1.30 , prepared to get lashed on for the afternoon ... sky looked ominous ...
my ride for the afternoon .....
and a couple of views from the cage :giggle:
there is sawdust everywhere ....
talk about fire hazard ....:ROFLMAO:
we had a 2 gallon watering can in the basket with us :ROFLMAO: ...
which we needed at one point, on the cherry picker, when one of the knuckles just below us caught alight with all the oily sawdust trapped in the joint ... hadn't noticed 'til Russ sat there blowing his horn, watching flames lick up the boom :ROFLMAO::ROFLMAO:
when they said that's it we got wrapped up in double quick time ... Russ is up top stowing it all away and I'm on the deck pulling the legs in ... the sky was BLACK behind me !!
about 20 seconds after I took this shot when we were ready to 'get the flock out o' there and'd 'saddled up'
huge lightning flash, massive crash of thunder and it absolutely p*ssed down .... perfection timing .... would not wanted to have still been in the picker - had had me wet gear on all afternoon, waiting for it --- and it missed me :ROFLMAO::ROFLMAO::ROFLMAO:
thought you'd all like this one ... cyclone #1's fate ... second one went in on top :giggle:
View attachment 64673 View attachment 64674View attachment 64676View attachment 64675
View attachment 64670 View attachment 64669
Same for us 1 big clap and lashed down just finishing as it came down working in near you
as in-- near Pontrilas or Druid central?
certainly came down though ..... pulled the crane round to where my car was parked and sat there for 10 minutes for it to ease off, 'fore I jumped out and transhipped my gear into the boot
Central
the weekend's rainfall .... :mad:
think the green one's got a leak .. was more in that yesterday :unsure::rolleyes:
much better today -- although didn't look too promising most of the morning .. so spent some time cleaning a few bits up .. 'til the sun started to show itself... and I got a bit more enthused about having a go ....
katsu box is a 240v die grinder ... great for polishing up rusty holes and de-burring
got this set up and then braced up
so's i could pick it up wholesale and plonk it where I wanted it to end up ....
then started on consolidating it ...
and adding 'extras'
as they're only 12mm cheeks, thought I'd better add a few spacers to avoid deflection ..
lot of positional runs ... 's too bloody heavy to man handle any more than I did/could manage :( so'll cap a few off 'again' when i get a 'lifting facility' wound up to roll it
that tail plate and the length of 76mm CHS in the middle ought to keep it nice and stiff --- 70mm pins'l also help a lot of course :giggle::giggle:
managed to get those bottom rollers and their pins off the other day ... lower, upper rollers co-operated too - eventually ... with a couple of wedges and a 5lb hammer ... top ones ain't having it ATM .. but they will ;):):giggle: (y)
little sods took some getting off
they were solid
be nice to get the rest off ... make it look a lot more 'finished'
and the obligatory pic for @Stock ... tonight's 'precious' exercising .... yet more garden crud meets 'the bin' :giggle:
better go put the lid on it, 'fore I go to bed ..... 'sposed to lash down overnight and like to try and keep the ash bed in the bottom dry ... makes for an easier lighting/burn :giggle::cool:(y)
day started a hell of a lot drier than forecast :giggle: so woke the 'Drema up to oss that lump of plate off the bench .. becoming a nuisance sat there ... been trying to decide where to park it and sussed spot I could keep it upright .. water standing on it has not been kind to it - some serious pits in it in places so got it slotted in between the 6t tipper and some other tish
gotta love a plate clamp :giggle::giggle:
while I was down that corner/end of the patch I thought I'd hoik out a large metal box I had sat up on a pallet (old chain box off my 30t Grove I replaced with a lockable, lidded alternative) as I needed it to sling a load of heavy lumps/bits 'n bobs into, off the little wooden bench, beside my two work benches, as it's been collapsing for a while and was in imminent danger of a total collapse ...
moved said box closer to where I wanted it
and started clearing it and binning some of the detritus that'd accumulated and the wet sh1t started ... carried on for 15-20 mins and thought - sod this - go have a coffee and hopefully it'll ease off ....
came down the house - turned on the tap - no water ????? - outside to the pump box - reset it - ran for 10 seconds and tripped again ? hmmmm?? :unsure:
went and grabbed some tools and disconnected the incomer at the pump - sod all ? ! :(
grabbed some more tools and headed up the drive to our tank - 'praps some muppet ( :rolleyes::rolleyes: - no names) has turned our line off :mad: ...
it is still lashing down and I am getting very damp ... :(
no sign of anyone being near it and had to fight my way in through the undergrowth to check -- all full and overflow running - all taps on ..
Odd:unsure:
back to the house and work my way back up the line, from the pump, into the house - getting ever wetter - nada - got back as far as the incoming inline ball valve in a kitchen unit - a trickle :unsure::unsure: -- wrestled the flexi with the ball on the end back through a hole in a unit, barely big enough for it, so I had some flexi to play with, found a bucket and took the ball off ....
oh yeh - PLENTY of flow, t'other side of that - glad I had the bucket :oops::rolleyes: :ROFLMAO:
half a mile of 1" MDPE pipe and about 50 ft of head behind it :oops:
So I've got me thumb over the end of the pipe fitting trying to keep a LOT of water in the pipe and trying to look inside the ball valve .....
Aha.....
a valve full of roots -- this is all upstream of the filter system :censored:
wrestled the ball valve back on the end of the line - eventually - getting wetter, yet again and went off to find a blanking cap, so I could have the valve off and two hands to mess with it -- wrestling an end cap on was wetter than the ball valve - had hoped I had a spare in stock, but no :( ... well I did but it was 1/2" - 3/4" , so had to settle for the blank and get the old valve cleaned out .. two spares are top of the shopping list for the next visit to town :rolleyes:
got all the lines re-assembled to the pump, ball valve free of detritus and connected it all back up .......
and we had water again
job for the weekend ...
go get the lids off the spring chamber and the settlement chamber and see WTF is growing in there ... first time I've had this problem in 14 years living here
amazed that lot had found it's way down half a mile of MDPE, numerous fittings (with inserts) and got as far as the end of the line (thankfully - would've taken some finding if it hadn't)
had I not found that, the next trick would've been 80psi up the line and blow it back through.
If that'd failed it'd've been a pump and an IBC full of H2O back pumped up the line :rolleyes:
Would've been a lot less grief on a dry day though :rolleyes:
so then went back to the bench task after all that tish ... and got even wetter, but had to be done - I'd left the 'Drema hovering over the steel box and was amazed it'd only drooped about 6" ... finished clearing all the lumps off the dying bench into it and parked it out the way for now
said collapsing bench -- have had it a long time -- and was a fair age when it came into my custody - ex school metalworking bench :rolleyes: and has been groaning under all sorts of off cuts, bit an' bobs, old bucket cheeks, teeth - all sorts for the last ten years at least :LOL: ...
found a few bits I'd forgotten I had too :giggle:
put a bucket on the floor for some of the smaller bits and it had half an inch of water in it in the hour or so I spent 'sorting' - unreal o_O
poor old girl's gonna end up in the wood shed, like t'other one did a few months ago :rolleyes::cry:
be interesting to see how bad the 3mm plate top is on it (must put that bit of 2" S/s mesh back out the way too ) :)
the most annoying part of all this afternoons shenanigans was .. it stopped raining and the sun came out as soon as I'd locked up and come in for a warming shower and climb out of my soggy clothes :mad::mad:
View attachment 64889 View attachment 64888
View attachment 64886 View attachment 64887
Odd:unsure:
Aha.....
View attachment 64885 View attachment 64883
Yeah just as we finished up
