Bobcat telehandler
We are fully aware of your input dooby boy, self appreciation rarely ends well..
Thanks all the same
PMSL :ROFLMAO::ROFLMAO::ROFLMAO: ...... Doob's an alright dude @jodb69 ;):) and'll tackle anything
dooby boy 😂
connotations of "you piece of farmer boy" levelled at Trax in the pipe pusher thread on CEF ..... that was a classic :ROFLMAO::ROFLMAO::ROFLMAO:
Well well well,
As I suspected a bit of a narcissist, likes to condesend when he can to cover his own insecurities .
I will take my dogshit machine and shite skills and make them better, whilst you on the other hand will be a sad little or big man for the rest of your time.
Presumably you will only be giving advice to people from now on who have pristine machinery ??🤷🤔🤣🤣
put the shovel down -- you've dug a deep enough hole Boyo ;):rolleyes:
jodb69
jodb69
If you'd have done what I said you'd be well on the way to having it fixed it by now.
Instead you keep asking, hoping that someone will say 'replace this fuse mate, problem solved'.
Plant doesn't work like that.
I have been taking on everybody's advice and doing bits at a time and I am going to try your method today as its the only chance I have to take someone else with me to read the meter while I try the pre heat, also the machine is a drive away so only bits at a time can be done.
jodb69
jodb69
All in good humour guys, Dooby, apologies if i offended ,none meant.
I can build things standing on my head, however I'm new to owning plant ( got the telehandler and TB 216 digger to assist in my development company and trying to get a handle on maintaining / service and repair of them.
Appreciate all the helpful responses 👍
jodb69
jodb69
Ok guys
So battery was at 12.7 this afternoon so no post charge over night.
Hooked it back up, dropped to 12.4 when turned to ignition, dropped to 11.3 on preheat and it's showing 13.9 when engine running.
I'm guessing glow plugs are working then.
I'm thinking of just swapping the battery as bobthebuilder said.
jodb69
jodb69
Also is a pic of the fuse box, all fuses are working , we changed the bottom right 15a one and the dashboard illumination when turning light on came alive.
What are the top right black ones, just blanks? There is no continuity in them any way.
In terms of relays, the one that isn't connected is what I think is the radio one, altho the radio was working and I hadn't touched anything in the fuse box.
Got one indicator not working on front of machine, and on rear no reverse light brake lights and n/s side light.
I'm going to swap bulbs and see what happens.
Any advice on this and the battery readings etc. Would be welcome
Plant & machinery is a funny thing, you need all the lights & fuses working before you go any further.. they throw up a hissy fit for no reason.. a new battery would be my next port of call after all that(if the one you have is a old one)
jodb69
jodb69
Thanks Dave, I'm getting one tomorrow, I looked on Bobcats recommended chart and it says 31a type.
Should I stick with that or get a more powerful one?
I’d just go with what they reccomend.
Anyway, what kind of things do you build? Your own projects or for loving customers? Nice place in your profile picture 👌🏻
jodb69
jodb69
Ok.
I do my own properties Dave. The one in my profile pic is a large project we are on at the mo for a long term customer,
I dont really work for the general public as they are a pain in the arse..
Along with all this I do alot of motorway service maintenance work.
jodb69
jodb69
Ok.
jodb69
jodb69
The job in the picture was originally just a garage conversion and extension.
It turned out..
Garage conversion
Extension size of 2 townhouses
Loft extension on the extension
Under pinning
Loads of walls out
Extensive steelwork
Floors out
Posi joists to existing loft
Steelwork in loft to carry purlins
Alter all existing doorways
Dpc
Board and skim whole place
En suites go every bedroom....
You name it it's been done ..
Ok guys
assume you mean it hadn't changed despite an overnight charge .... I would expect to see it at 13.7V coming off charge ... get a new one ... have had 'em showing 12.7 before and wouldn't turn a little petrol engine over
jodb69
jodb69
Sorry
No it wasn't charged overnight just disconnected , so barely dropped at all since it was on the machine
Sorry
colder weather will sort out any weak batteries .... for the sake of the aggro, a new one'll see you through the colder months :rolleyes: ... and save the starter from a lot of grief too
