bobthebuilder
check the battery under load ,ie cold morning cranking,
Whata best battery to put in this machine matecheck the battery under load ,ie cold morning cranking,
PerkinsWhat engine?
Just rule out the battery by attaching a jump pack.This is in it at the mo.
Had multi meter on it after taking it off and reading 12.76.
Gonna take another reading on Monday morning
Yes I have a charger / starter I was going to do that Monday.Just rule out the battery by attaching a jump pack.
Check the battery terminals and all earth straps for corrosion as this will cause slow cranking.
If a lot of dash lights aren't working I'd be checking the dash earth (s)Yes I have a charger / starter I was going to do that Monday.
Because it was a bit warmer this morning (10 degrees) it started fine.
5 degrees the other morning and i thought it wasnt going to go..
I'm suspecting no preheat, altho I checked fuse and relay with multimeter and appear to be working..
So why are certain lights on the dash not working , I.e glow plug, hand brake, crab steer , rear wheel alignment?
Do these bulbs complete a circuit?
Sorry to sound ameteur ( I am in this respect)
Said that two pages agoKeeping it simple, you`ve found the battery and got a meter, turn the ignition on and read the battery voltage, turn the key to the heat position hold it there and read the voltage again (you may need someone to help) it the heater plugs are working, there should be noticeable voltage drop.
That must of been yesterday, I slept since thenSaid that two pages ago![]()
1104 i think mickWhat engine?
thers one big earth on them behind the cab next to the boom ,its a one piece tray under neath and the main big bolts holding the cab on do come loose ,but on mine i had similar issues ,had starter done, checked every thing ,but no good ,changed (what i thought was a good battery )for the biggesy varta i could get in there and problem solvedIf a lot of dash lights aren't working I'd be checking the dash earth (s)
The bulbs don't neccesarily complete a circuit, the glow plug circuit is probably 30 amps! Instead they are relay driven or driven from the same signal that drives the selected command.
Thank you Bobthers one big earth on them behind the cab next to the boom ,its a one piece tray under neath and the main big bolts holding the cab on do come loose ,but on mine i had similar issues ,had starter done, checked every thing ,but no good ,changed (what i thought was a good battery )for the biggesy varta i could get in there and problem solved
We are fully aware of your input dooby boy, self appreciation rarely ends well..Said that two pages ago![]()
Thank youKeeping it simple, you`ve found the battery and got a meter, turn the ignition on and read the battery voltage, turn the key to the heat position hold it there and read the voltage again (you may need someone to help) it the heater plugs are working, there should be noticeable voltage drop.
If you'd have done what I said you'd be well on the way to having it fixed it by now.We are fully aware of your input dooby boy, self appreciation rarely ends well..
Thanks all the same
