3.5t Twin axle trailer movers or similiar
Any one had any experience with any of the motor movers like the caravan version but with way more capacity?
Happened to come across a video of a guy moving a car trailer (although was empty) into a really awkward spot which according to them would be "impossible" to do with a vehicle. To be fair it does look to be that way to get it out but might be doable to get it in.
I don't really struggle to get my trailers in but with nights getting darker it can be a bit of a ball ache as it is tight getting the plant trailer in as have to squeeze past the tipper and a wall which is 500mm or so of free space depending on how the other trailer has lined up.
Could probably rig one of the track dumpers but as they both sit on the tipper it's not really a viable option.
Ground is currently stone and gravel
I've said about similar our yard is a nightmare to get in and out of during the day
I would of thought they should work ok, I`ve heard of people when they have been stuck on a camp site, they used the caravan to push the car out using them.
there’s some that will do 3500 looking at their list of different manufacturers
I'll have another look I went through all there new listings and a few of the popular ones but none of which went above 2.5t for 4 units
I looked at this in detail a few years ago. Hard to do on IW trailers for various reasons. Found a couple of workarounds for us. Put a front ball hitch on the Dmax helps a lot Ball hitch on the Tracked carrier is another useful tool. Will try and find a photo....
Darent think of the cost but this could be handy?
Literally just been looking at them, was a barely used one on eBay that was up for £3450.
Trailer mounted ones are out of the question as would need two sets and more costly than that used mover, looks like will be adding some floodlights and trying not to scratch the ranger
Can get tracked ones, seen one in an auction recently
Need a bit of weight to it and ability to get the drawbar up high enough on to put decent weight onto the mover.
You can get powered jockey wheels but never tried one and would need good surface to work on
was looking at one on FB MP an hour ago ... see if I can find it again
got it .... only 1500kgs sadly ... neat looking weapon though -- there's a vid in the listing - it looks like new
4500kg on ebay
How solid is the stone and gravel?
Sounds like an excuse to spend the same money as a 'camper trolley' and get a forklift. Add some big old LED lights to it too.
I just clamp a ball hitch bracket that I made to the end of the forks, but you could cut a fork down for ultimate manoverability.
