Exactly.... cant be greedyYou even have 100kg to play with![]()
No transport manager needed on a restricted o.Not so much the application it's the 6 weekly checks, tacho, transport manager unless there is less involved?
Not sure if our yard would get 1 as parking is an absolute nightmare around there these days too.
Tacho....been looking at this for pickup and trailer...do you lot with wagons on local stuff still use the 100k exemption or ?No transport manager needed on a restricted o.
If its a Commercial yard it doesn't matter along as you've space and permission to park it there.
Tacho hours, well unless your doing mega hours constant driving they won't affect you.
6 weekly, Yes it's a cost but it isn't that much. It can be upto 13 weeks dependent on a few things.
There's many things to consider but I deffo regret not doing it 10 years previously.
It’s silly in that you can’t actually do a test for the setup you want say your only aspiration is a 7.5 ton and trailer. You have to do a 40 ton artic test instead of the actual rig you want.
" C+E or C1+E ?Apparently when you chop a uk licence in for a french licence you get 3.5t towing on 7.5t so c+e... but if you take your hgv your c+e comes back with a restriction of 3.5t limit.
no tacho within 100 klik radius of operating base.Not so much the application it's the 6 weekly checks, tacho, transport manager unless there is less involved?
I'd have to do c + e lorry is fine trailer notno tacho within 100 klik radius of operating base.
6 weeklies can be negotiated if your mileage is low (IIRC mine was 3 or 4 monthly as only limited local mileage)
Unsure on the CPC crap though - Rory'd be the boy to inform you on that
restricted O license isn't that difficult, other than having sufficient funds in the bank - permanently
you may find that a C pass may give you C1+EI'd have to do c + e lorry is fine trailer not
C1e" C+E or C1+E ?
just C (old class 2) or C+E (old class 1) test?
C1+E is a sub category of C+E, passing a C would just give you C1.you may find that a C pass may give you C1+E
It is also age dependant, older the truck, the more often they ant it done.6 weeklies can be negotiated if your mileage is low
