Van Prices 2024
Yes! If the battery is charged it will tip anything you can fit on it…
Got to be 16ton on that one 😂
That's the problem In itself. You think your going great until the battery goes flat and you have to hand pump it. Definitely would recommend fitting an Anderson connector to the front of the trailer and either another Anderson on the back of the tow vehicle or seeing as I'm sure most on here carry jump leads anyway, then just fit a pair of Anderson plugs 3/4 of the way on your jump leads
3/4 of the way from which end?…
Was considering swapping my gx126 for a 12ft tipper.. having drop sides for pallets would be handy, along with a tipper & still being able to get 3 ton swivel on the back! Does it fit within the sides? Or does it need to be in flatbed mode?
I was looking at tipper trailers the other night but payload on most were around 2.6t bit too close for the avant and ez26
Done exactly this
The trickle charger leads on side not enough for jumping it
Was playing up, battery was testing fine on davensett charger but had corroded on terminals cleaned it up and fitted davenset then have plug in truck for connecting up jump pack
Mine won’t, it’s shocking at tipping heavy stuff ram is mounted al wrong for it can see it lifting middle of bed but won’t tip had to shovel fair few loads to back to get started or help it to get going with digger on corner
I’ve never had an issue with tipping power when fully charged - have had some terminal corrosion issues that have had an affect over the years though.
