I have a cheap 50 quid one I got on eBay it's ok and will weld bits together adequately but my uncles decent one (which I can't remember the brand of) is loads better only thing is inverter welders don't like long extension leads or generators very much
If you plan to use with a generator you either need a generator suitable for use with normal inverter welders or an inverter welders suitable for use with normal generators.
And everyone I know is always full of praise for how long an extension lead they will happily run off. I've had my r tech on a 30m extension lead. And my old man had a Lincoln on two 50m extension leads. I've seen blokes with them on the strap over their shoulder up ladders I the roofs of steel framed buildings with extension leads trailing away, with towable welder and all its leads left parked in the corner.
