rooster cogburn
What would be a suitable cost effective hammer to make into a post driver for 8ton digger. Would be better mounted down side.
@Dr pecker is your man to answer this question @rooster cogburn .. presume you mean side mounted as opposed to top mounted - My guess would be a yesWhat would be a suitable cost effective hammer to make into a post driver for 8ton digger. Would be better mounted down side.
Yep bought my Auger from him Dr p seems sound tooThis chap has also sold to several members in the last year or two ..
he's local to me and have known him a looong time -- he's very much legit, as is Nigel (dr pecker)
Paul Peacocks – Hydraulic Breakers, Post Drivers & Earth Drills
Providers of new & professionally refurbished Hydraulic Breakers, Post drivers, Driving Cups & Augertorque Machineswww.hydraulicbreaker.co.uk
I've bought couple bits from Paul. Proper leg end and lots of good advice, fair transparent pricing and good service. Would use again.Yep bought my Auger from him Dr p seems sound too
SameI've bought couple bits from Paul. Proper leg end and lots of good advice, fair transparent pricing and good service. Would use again.
Assume you mean breaker converted ones Vs drop weight as per protech etc?What would be a suitable cost effective hammer to make into a post driver for 8ton digger. Would be better mounted down side.
I got a price from him 6 years ago, but he wouldn’t put it down in a email and I forget what he said over the phone now! I’m sure it was £500 odd for my breaker to go on 8tonnerThis chap has also sold to several members in the last year or two ..
a used one presumably ... see he sells re-con.s too .....I got a price from him 6 years ago, but he wouldn’t put it down in a email and I forget what he said over the phone now! I’m sure it was £500 odd for my breaker to go on 8tonner
he means the cup not the breaker I got one off Paul for my 1.5 ton breaker was £500a used one presumably ... see he sells re-con.s too .....'s very much Paul
worse, mast is the professional choice. breaker is ok for odd post etc but keeping them straight and inline is trickyAre they better/worse than a mast post driver.
This - my breaker was around 8k for a new onehe means the cup not the breaker I got one off Paul for my 1.5 ton breaker was £500
you can run any size you want basically can run a 5 ton hammer etc doesn't need to be an 8 ton hammer
Does your kinghitter have back shift on it? Farmer friend had one and it would only sideshift which meant faffing around with tractor position if the post drifted on a rock or root.Like I say its ok if dead straight isn’t required but on say post and rail on a ménage it’s tricky to get them perfectly straight and 1.8m spacing for rails etc where as with a tractor or tracked knocker you can finesse it with hydraulic side to side and back and forth to get it mm perfect
I bottom mount it on 3 ton where it can catch you out but have it mid mounted on 5 ton on the big steels its an all terrain fencing weapon, mid mounted can reach over stuff to drive posts etc
On the same size machine a drop weight will have far more smack than a breaker. 8 ton it should be ok on strainers though- all depends on ground.Are they better/worse than a mast post driver.
