Davy Bull
Hi all, have lost 1.2.4 gears in forward and reverse and I have 3 but only revs to 1400rpm
They did just all of a suddenDid all them issues stop working simultaneity?
I have read similar before some where .... weirdest of issues on those m/cs, for the weirdest of causes ... gotta love CANBUS's idiosyncrasiesGoing to sound daft but check all of your exterior light bulbs…replace any blown ones. I’m guessing it’s a pre 2015 ish machine?
did the dash have idiot lights to tell you of a bulb failure ?I had a new 2009 3CX contractor , it was a sod for blowing rear side light bulbs, sent it into what felt like limp mode, think it created an earth shortage or something similar.
Carried a full bulb set after the first time!
Think it was pre canbus system, relays and fuses.
Nope.. never been in a jcb that does!did the dash have idiot lights to tell you of a bulb failure ?
On occasion the 432 would blow a random 10amp fuse, can't remember what it was for, but it'd shut transmission down.Nope.. never been in a jcb that does!
My JD has all that, tells you everything in the computer - instant diagnostics.
Powerslide fuse would blow on mine which took out half the machine, but it didn’t show up on any electrical plans - factory at somepoint in time had piggy backed aload of random bits into that circuit. Standard making it up as they go alongOn occasion the 432 would blow a random 10amp fuse, can't remember what it was for, but it'd shut transmission down.
Caught me out the first time. But I'd made sure it didn't after I knew about it. Apparently a common thing on them.Powerslide fuse would blow on mine which took out half the machine, but it didn’t show up on any electrical plans - factory at somepoint in time had piggy backed aload of random bits into that circuit. Standard making it up as they go along![]()
