What size digger will lift a 1 ton bag?
Stoph43
Hi all. I'm trying to spec a digger to buy for a long self build project. I'm currently looking at ay JCB 8018 CST or a Hitachi Zx17
Does anyone know if either of these will lift / unload / move around a 1 ton builders bag? I'm trying to workout if its worth going for an older bigger machine (2.5 - 3.0 t) or whether to stick with a smaller machine with less hours etc.
I only have a £10K budget some am looking for as much advice as i can from your guys experience.
Thanks in advance
Buy a forklift.
Diggers are for digging.
Even the cheapest crappiest 1.5t forklift will throw 1t bags about with ease. Right tool for the job.
assuming you have solid enough terrain to move about on ...... do not underestimate the ability of even a 1.5t FLT to get it arse bogged in what looks like decent ground ... empty, all the weight is on the two back wheels (usually the smallest ones) -- want good ground to use a conventional FLT on ... and you'll pay roughly the same for a 2-2.5 as a decent 1.5'll cost you - get about better (bigger wheels) and have far more capabilities
A 2.8t will just about do it. But real world usability will be crap- think lifting of the back of trailers etc. 5 ton minimum and even then you'll have to be on the ball. To actually lift anything to a useful height it will mostly be at the far reach. 8 ton to lift it comfortably at far reach IMO
you need one of these ... sod peeing about with piddly little diggers or FLTs :ROFLMAO::ROFLMAO:
limiting factor on this is the strength of the forks :LOL::ROFLMAO:
I have a bracket for a manual thing on my Kx71-3. It is very useful for hanging a short chain from and handling bulk bags. Can get bull bags off the rear of the plant trailer and over the side of very careful. I drop the bucket off when lifting bulk bags as it is on the edge!!
Yes I used to do similar before I fitted the thumb- like this- gives a useful bit of height and capacity. Tracked 27 bags down a path like this.
Thanks in advance
If it's a self build and your not needing to transport it you might be worth looking at the 3.5t sort of size. Generally more metal for your money than anything towable but also should be able to lift dumpy bags around the place if your carefull about it.
