2.7t??
JoeS
Just to be devil's advocate. I have an 8ton and 2.8t. just as happy in the 2.8t for a day as the 8 ton. The 2.8t gets waaay more use. It depends on jobs of course but the smaller machine fits in places, easy to transport, very frugal on fuel, easier to get in and out of if it's one of those jobs. Have also had a 5 ton. For me it was exactly as you describe- not big enough to do the meaty jobs but still hassle of transport etc- again would take the 2.8t most of the time.
Been in my 1.8t a bit recently. Suddenly realise how much more capable and enjoyable when I jump back in the 2.8t. I don't get that same gratification when going from the 2.8 to 8 ton. Although again some jobs the 2.8t clearly doesn't have the grunt or bulk shifting capacity.
i can move it about easy enough though just not sure which way to go? i do wonder if i just have a half decent 2.7t and just wait to add a 9 later on rather than trying for a 1 size fits all
I dont know your work but think that would be a good way to do it. Easy enough to sell on a 2.8t if not the right machine at the same time cheap to hire the big machines in as and when untill your sure you have enough of the right work to justify your own?
Used to pay 140€ a move for the 8t and did so for a long time - but wouldn't of paid out to move a 5t when I could move a 3t myself.
Ive been through pretty much all the scenarios and they all have their pros and cons.
But if you can move up to 8t and only have one size machine to cover the various bases then apart from needing a 1.5t occasionally a 5/6t must be best as its in the middle.
Loads of possibilities...newish main machine that gets the stick and older others for occasional use.
Not myself. Which admittedly is half the problem but honestly for the majority of jobs I find a 2.8t fine and makes a good attachment carrier. The big one only really comes out when really needed and as you know it's for sale because it costs me say £200 each way delivery- so thats £400 per job as cant always tie it in with another job. Local plant hire will deliver whatever size I require for £60. When mine has gone this is just the easier way- hire in big machine for bulk work and leave the 2.8t to do the rest- which in my case is probably about 80% of my work anyway.
Plant hire delivery is usually bonkers cheap. Guess they usually tie in with other trips to maximize efficiency.
Sounds like my situation.
The ease of moving the 2.7ton machine is a major win for me compared to the 8ton machine. I have the 8ton at home on the farm but still jump in the smaller machine most of the time.
do you like the et65? i thought the et90 was a fairly good machine
Dont know if thats tight or just looked tight after the 8t kub.
About 6.5cm
15t hookloader
Beaver tail is a one trick pony ...might as well have something otherwise useful
Hook loader would be the way to go. But in fairness, when the 8tonne goes out it generally stays for quite a while and I usually have more work for the kx71-3. I guess if I had the lorry more work the the bigger machine would appear. But as much as I look at hook loaders, I am still not keen to get back into operator’s licensing and tacho rules etc etc!!
