3t selector grab
Thomas7740
Thomas7740
Considering get a rotating selector grab for the ez26. Any recommendations on make and model etc? What aux services do they require? Ours has one aux, which is on the left joystick, assuming a rotating grab needs 2, so can a solenoid be put in and press a button to swap between rotate and grab?
Dala-gripen, ideal for your machine. We can put the solenoid on to swap or add extra lines for not a lot
nice .. would look so much better/neater with the 6 x 2 diverter to rotator plumbing in steel though :rolleyes: ;)
For God's sake divert the offset not the first aux. Not being able to use both the grab and rotate at once would be like having one hand tied behind your back.
I guess then you could just use a manual tap to divert rather than solenoid.. at least your only partly debilitated
Been very pleased with my Intermacato TG16U (I think). Can get a grab of soil with it if it's not too dry!
Did nearly 400 meters of granite walling with it back in the autumn, did all the rebuilding with the grab including backfilling soil and it's wearing well, a bit of the corner of the plates worn down but can easily turn the plates round if needed
@Thomas7740 if your feeling like spending a bit of money what about one of these. Same as what I have on my 8 tonner. The hpx drive is ace. Can either get with teeth or no teeth and the proper shell makes for better handling of loose material. Think youd need the A02hpx
the Kinshoffer HPX drive is good, but they are a hell of a price in comparison to their ram actuated grabs/grapples/clams and even more eye watering compared to other manufacturers' offerings :oops::cry:
the interchangeable shell system does give you some flexibility and options -- at a price
Thomas7740
Thomas7740
That’s a lot more than we need, plus it’s over double the weight of the dala gripen Aiden posted above. Looking at a few options but the dala gripen seems to be the best option
Yea really well thought out like
Yea hold in button on RHS side joystick to go from grab to rotate
Crikey- Id have thought will ruin the rhythm big time. Could it not have been diverted from the offset itself? Or is it because you only have one set of aux which is in itself already diverted from offset?
