You sure the solenoids are shorting out or just not being supplied with power due to a faulty connection, sensor or controller? All the light means is that the solenoid is being energised. So those other solenoids might not be energised due to a system fault, correct operation or the system deliberately not allowing power to those valves.
there is power to the plug ....
I have had one where although it was lit, the connections from the plug to the solenoid weren't making proper contact - whip the solenoid off put a steel rod/bolt/screwdriver in the centre and check it is actually producing a strong magnetic field
if it ain't try it with an independent power feed - if that works it's the plug - don't trust the meter in the plug connections ... have also had one showing 24v, but such a poor connection it wouldn't supply the solenoid with sufficient current to operate it and produce a strong/full magnetic field
or...
could get a couple of DIN plugs and put some direct feeds to those two solenoids (over-riding whatever isn't feeding them) and see if all is well
( I have a couple of over-ridden circuits on't 'Drema 'cos the dash's switches can be temperamental - power feed through a separate switch [one leg and axle locks] )
better to have some spares sat about
or just buy a few
I've always got half a dozen or more sat about - never know when one is gonna give you grief
second pic looks to be the servo control / feed valve bank for sticks/pedals/slew/etc.. controlled by the dead man switches - hence the single solenoid at the top......
pipes - top down --- left and right stick feedds, -- tracking lever feed , -- slew motor and brake feed, -- tracking lever feed ...... would be my guess without actually laying eyes on the beast
Behind thise red caps there is most likely an over ride screw .
Screw it in or out to manually over ride rhe solenoid!
or could even be a push button over-ride Aiden .... all the Cetop3s I have are a simple push button - push with a point of some description -- I have one screw in on the 'Drema - everything else is push in to over-ride
