Management
I reprogrammed all our stats 1degree lower than the Mrs had set, she’s hasn’t noticed yet
Pam'd have fans on everywhere if we ran at 21Cyeah i know right, i feel the cold with my back i suppose, i personally am happy enoguh at 18-19 and wood burner but i have kids and all that. In our old house we ran the heating twice a day to 21 and the inbetween was set to 18 and very rarely kicked in
yeah every room is zoned and we have god knows how must insulation, tripple glazing etc.
i really dont know how to use it is my issue, currently i am letting it drop down to say 17 degrees which is to cold as we want it to 21 in the evenings.
im going to change it to minimum in each room of 19.5 and to peak at 21.5 during times at home.
If you are using 230v stats to control an ASHP you’ve already identified part of the problem. ASHP should (ideally) be on a big open loop with the correct supplied controller operating as a load compensator in conjunction with the external sensor . Using 3rd party controls is undesirable and will usually harm your SCOPso we have just moved into our A rated for effiency house with airsource heatpumps and full underfloor heating.
its a learning curve so far but it isnt very efficent. or doesnt feel it, i need to understand some parts of our use but the old house was a average or 30kw a day i think, the other day at the new place it pulled 130kw, average about 80 kw a day so 50kw going on heat.
i think i have the temps set to cold and then wanting to get it to warm so going to change the thermostats today to work out
Hear pumpis it heat pump or boiler ?
That probably is it . Again will look at it there not smart controls likely a load of shite also a few years oldIf you are using 230v stats to control an ASHP you’ve already identified part of the problem. ASHP should (ideally) be on a big open loop with the correct supplied controller operating as a load compensator in conjunction with the external sensor . Using 3rd party controls is undesirable and will usually harm your SCOP
You don’t want smart contols-you want something that works with/talks to the heat pumpThat probably is it . Again will look at it there not smart controls likely a load of shite also a few years old
keep it simple ,You don’t want smart contols-you want something that works with/talks to the heat pump![]()
19 is our heating on temp lol and we’re spending £500 a month in gas and electric lol but 1936 house with not enough insulation yetas i say i need to look at it in more detail, this morning the heating wasnt on when i got up and it was about 19 degrees in house but it felt a cold 19 degrees if that makes sense so going to need a morning blast . It must be pretty air tight a house given its rating and all that but its a huge old space at about 4000 sq ft.
Wow 500 a month. Ours is about 1000 litres of oil (£600-£700) a year and £130 a Month on electricity. Wood burner on most nights in winter19 is our heating on temp lol and we’re spending £500 a month in gas and electric lol but 1936 house with not enough insulation yet
I mean this place is 1930s too. And should do less than that but it shouldn’t be so complicated, once I have my pc setup il look more into understanding the system . We have 26 410w solar, Tesla battery’s and air source heat pump with underfloor heating throughout in likely trying to cool it down to much , and not letting it just simmer .19 is our heating on temp lol and we’re spending £500 a month in gas and electric lol but 1936 house with not enough insulation yet
wow indeed ..... leccy is £110-120/m and kero is circa 8-9lt a day, this time of year ... much less in the summer .. cook electric ... annual kero is up a bit from yours at prob.s 1250-1300lts over the full year. .. barn is late 1600,sWow 500 a month. Ours is about 1000 litres of oil (£600-£700) a year and £130 a Month on electricity. Wood burner on most nights in winter
The temp set in here of 22 feels more like 18 at my old house so going to need to understand that too
I’ve just built a garden room that’s 150.mm celotex walls and 200mm roof and floor all taped and moisture barrier even un heated the rooms warm just having small aircon for heating and coolWe had same dilemma, 1899 house, solid walls. Biggest issue is making sure you dont move the dewpoint inside the house when insulation and creating damp. The dew point ideally needs to be inside the insulation so damp cannot form but is quite difficult to achieve using internal insulation alone unless its thick and has service void. Just slapping on 25mm celotex plasterboard everywhere can cause more issues than it solves.
1800 s 4 bed house here at 750ft asl ,85 a month for leccy ,800l of lpg a year average ,10 ton of firewoodwow indeed ..... leccy is £110-120/m and kero is circa 8-9lt a day, this time of year ... much less in the summer .. cook electric ... annual kero is up a bit from yours at prob.s 1250-1300lts over the full year. .. barn is late 1600,s
