Wacker Neuson dumper not charging
L
lloydjames
That's what I thought, I ve removed the key from the isolator switch and the battery has still drained, unless the isolator switch is faulty as well, I'm not mechanical minded, so I ve googled issues but theres so much electrics on there it's a mind field, but I put a.new.battery on it the other day,turned isolator off and the battery still drained dead,
L
lloydjames
shouldn't be anything connected to drain it, if the battery is isolated properly ????
A.fully charged battery will last about 2 days before it goes dead and it won't start,I can jump it but then the automatic brake will just kick in them and it won't go in or out of gear,change battery for a new one and all is fine again until about 2 days later same issue,
so it's draining whilst running? who checked your alternator .. if it's good it should keep it fully charged
L
lloydjames
I took it to a place in tredegar who reconditions them,and he said everything was fine with it, that why I'm thinking it could be a faulty relay, can you think of any other tests I could do on it or anything else I could check,
Negative terminal off and multimeter in between terminal and battery, see what the number is then start pulling fuses/relays till it drops.
If the battery is 80ah and fully charged, that's 1 amp for 80 hours to discharge the battery, so in 2 days it would need to be drawing 2 amps.
Get it running nd see what volts are at the battery if it's less than 14v start looking at the wiring or potentially the alternator/generator/rectifier is dead
L
lloydjames
Many thanks for the reply and your time,I will try this out tomorrow 👍
start and charge? shed down the back street at the bottom of some one's mum's garden ... know it well - good guys - if they say it's OK it is
does it have a separate regulator box ? they're a prime suspect usually
That's the place, I'm not sure I will check tomorrow,do you know where these would be on the thwaites 1ton dumper,thanks
follow the wires from the back of the alternator - if it has a reg. pack it'll be there somewhere
Steve
If it has a separate regulator they are often fitted in the battery compartment or near the battery so that it can regulate the alternator allowing for voltage drop through the length of the battery lead.
L
lloydjames
Thanks for this Steve,I will check tomorrow 👍
but on a machine of that size ...... could be anywhere ..... on my cranes they were all over the place ... some in the engine bay, some in the cab ... no rhyme or reason :rolleyes::rolleyes:
Take a picture of the alternator! I think it may be generator and reg
L
lloydjames
Hi all,I'm not sure if this is the only cause,but tested the relays today and one is faulty it's the durakool dg56t relay,does anyone know the function of this relay on the 1 ton thwaites dumper, thanks 👍
sulky
Morning All,
I have a 1t high lift Wacker Neuson dumper that is killing batteries. Fully charged battery lasts about a day (average 5 starts max.). Even a brand new battery is ruined rapidly.
Checked all fuses and all ok.
Suspect a faulty alternator, but before I launch down that route, wondered if anyone on here had any ideas or experience?
Thanks :cool:
guy i know had probs on his neuson simular to you it was parking brake relay short on pins
L
lloydjames
Thanks sulky, I believe that's the same issue with my thwaites,the relay was faulty and draining the battery,changed it earlier and hoping that's the end of the problem, 👍,thanks everyone for all the help and advice,
