SIMON TOPPER CHERRY PICKER
mike G
HELLO EVERYONE They say the old ones are the best , so i would like to keep old simon going ,so i need a HALF SHAFT for him , is there anyone with one or a contact i could try please..THANKS MIKE 07815817390 .( NORTH EAST UK.)
assume it's related to Simon Snorkel ...
used to have a factory local, in Ebbwvale maaaaaaaaaaaaaaaany years ago, doing fire engine lifts
had 'industrial relation' problems (and their WDA rent/rates free incentive scheme/period had expired) .. Friday shift clocked off at 4pm ... came to clock on, on the Monday morning - place was empty ... they moved the whole operation, lock, stock and barrel to Scotland in 60 hrs ...... must've taken some organising .. was quite a big unit :rolleyes:
what's wrong with the shaft you have ?
mike G
hi dont know if topper and snorkel are related could be cousins:unsure: our shaft has snapped.
almost certainly, but don't think they emanated from Ebbwvale works ... they were into truck mounted platforms
that's an annoying place to snap :mad: :mad: ....
if it'd been more central I'd've suggested some 299 Mo/Ni/Cr rods to re-assemble ...
shove it through any restrictive bearing dia.s and split sleeved it ....
's only slow moving after all ...
have done it before and worked fine ...
the 299s'll weld just about anything - and hold .....
that is a PITA .....
any idea who's axles they are ??
A pic of the axles and hubs respectively would be helpful
6 stud and a fairly large PCD for the wheel size ... only 2WD too ..... interesting telehandler on solids in the background :unsure: .. waste transfer 'praps :rolleyes:
mike G
yes its a ford axle possibly same as old mk1-2 twinwheeler tranny
slung 4 complete ones in the skip when I cleared my yard :( ... made nice axles with the diff.s cut out :giggle:
