More digger porn
Engcon UK
Engcon UK
The Noble Art of Digging
Interesting one this. Opposite end of the scale to the two Ollies and others.
Two DX63s (from memory) ordered at Plantworx. Owner wanted just a simple tilt and rotate function onto a well-sorted machine with an existing quick hitch line and two proportional circuits. Direct mount.
No control system, just plug and play.
Pin the tilty on, make up the hoses and away you go.
wee_gus
wee_gus
Anymore photos? Was this the ones Neil and Glenn done?
Engcon UK
Engcon UK
tinydigger
tinydigger
looks a nice simple set up to get them started in the tilty game .was that work done at lamberts yard in garboldisham? as it looks familer to me also if i think it is the same company based in north norfolk then i do the inspections on all there lifting gear
Engcon UK
Engcon UK
Yes. Ordered through Mervyn Lambert five or six weeks ago.👍
presumably Robert, a gripper and aux would still be an option, all be it with an either/or set up on diverters?? :unsure:
Engcon UK
Engcon UK
Depending on the specification, Graham. Ordinarily the SS0 setup (no control system) comes without a swivel, so there are no extra services below the tilty.
I was quite surprised a couple of years ago when an existing customer (of our higher specification DC2 systems) bought one of these for a W-N ET90. He made the point that the digger was only ever going to be used for landscaping and this was the most cost effective solution.
On reflection, I think he was right. If you need the extra services, go for SS9, which allows you to 'borrow' the aux or gripper from the tilt function. The swivel and control system will add around £2500 to the cost.
......... If you need the extra services, go for SS9, which allows you to 'borrow' the aux or gripper from the tilt function. The swivel and control system will add around £2500 to the cost.
aye ... not cheap 'puppies', a rotary coupling :(
soljun
Looks revolutionary and dynamic! Thanks for sharing! I'm sure if you rent it, you will have many clients.
I can’t be the only one who scrolled up to see what was revolutionary and dynamic....🙄😂😂
Engcon UK
Engcon UK
I'm not sure i should be giving this guy any publicity, but it's certainly revolutionary 🤣🤣
Over to you Ross......
Engcon UK
Engcon UK
Again, hopefully something a little bit different. Ordered by and delivered within a week to Willowbrook and a nice tidy install by Arbgear for KKD (no - not something that we do regularly, we just happened to have the unit in stock:eek:(y)).
What's a little different is twin EC-Oil top and bottom setup - KKD are running a tree shear and a flail under this:
The other thing here is we are now standardising on our QSC hitch control for twin hitch setups:
The idea here is that usually the top hitch is an excavator function and the bottom is a tilty function - different hitch controls and different protocols. By standardising with this hitch controller you have the same process top and bottom. Requires ground pressure to initiate the sequence and won't allow you to hook the bucket to move it. Vid here (the boom and slew restrictions are an option):
