Ground Protection Mats
Yeah there are a few online doing buckets of 100 starting about 120 i was hoping to pay about £20 🤣
how about some 20/25 x 3 flats in pairs, say 30-35mm long ... drilled as a pair with a hole to suit a tek screw, then open up one of the pairs with a clearance size and counter sink for C/s head teks ... dog up and disc off what protrudes :unsure:
(and maybe even a dot of hot stick on the side you cut to length?)
Yeah was thinking of similar good idea with tec screws 👍🏼
Have some as well we tend to use these style for the muck while running on the thicker ones
These are similar to the ones I have. Nice and light and bendy - but you wouldn't want to run machinery across a wet lawn with them as too thin/soft. Anything more than a Micro/track barrow needs heavier ones.
Similar to mine we used 3t dumper loaded on terrible soft grd last few weeks, I'm genuinely amazed how flexible they are
T
Tintan28
I’ve just recently bought some very similar from multimatts.co.uk, I got 30 @ £55+vat.
I bought them for covering a rigid insulation based block & beam floor whilst SIPS panels are being erected etc prior to screed being laid. OSB would have £10-£12+ vat & probably not much use afterwards especially with the rain we’ve had. So this client will have paid me nearly a1/4 of their costs when I uplift them. They are fairly flexible but light enough to handle & will be ok for protecting ground with the light plant I run.
Basically new price?
Your link is for low density 10mm boards 1100mm wide. The fb ones look like medium density 1200mm wide maybe 15-20mm thick?. Big difference in function. Still not cheap at £100 though!
Groundboards are like plywood.. all different qualities and thickness and difference in use and difference in cost
groundworker
groundworker
He says 1100 wide, 10mm thick and 22kg in the ad, I did see it says MD but the ones in the link are 24kg so similar density? And visually look the same - single hand hold in each rather than the more common two (which mine have).
groundworker
groundworker
I've got the 12mm ones, mainly use them for grab piles or running mini machines over to save ruining a lawn.
They are definitely floppy though, sometimes that's useful but usually not - I put them down on a sandstone patio and ran the track dumper back and forward for a few weeks, half a dozen cracked slabs under there when I lifted the boards :cry: Ply would have been better in that instance.
Still invaluable in my opinion, would dread to think what I would have spent on ply in the last two years if I hadn't had them.
I’ve gone extreme with the last ones I bought .. 300kg each 🙄
