Possible new track barrow (Possible another project) 😀
Are those little self loaders actually any good or a gimmick ? Never tried one
I fetched a load of stone through someone's garage with one and it did what it says...loads itself 🤪
Only issue is when you've down to last bit it pushes it away rather than into bucket
shovel time ;):giggle:
Y
yanmarb03
Had some time this afternoon on it the people who had it before us didn't do the spark plug up ! That explains the water in there I sprayed some wd40 and left it a few hours and it has broke free thank god got no spark as of yet will have to dig into it abit deeper clean some of the contacts up etc.
It has been sat outside for 18 months so not surprised it needs some work oil stinks of petrol but they didn't turn the fuel off so again not surprised possibly the valve letting by he did say it has carb issues then again I don't know if it's ever been serviced?
no spark could well be why the plug was loose ??? :unsure:
Depends on the machine, our HP1500 and HS400 are f****ng amazing and function well as bulldozers (and gave been used as such on a couple jobs) the HS1100 is a Damp Squib, although I think that's down to the Yanmar engine being down on power and me being too lazy to sort it
Y
yanmarb03
Photos attached for those who are interested in the couplings on the side and controls
Y
yanmarb03
Obviously someone didn't like looking after it 🙄 it wants to start tho believe it or not but just doesn't it coughs and splutters etc think the carb is blocked up
fill the spigot with Devcon/plastic metal, drill and re-tap it to M6 ;)
Y
yanmarb03
I can't seem to find a hydraulic filter for the track barrow or what hydraulic oil it takes . Am I going to have to go direct to jcb ? I have tried inline filters and done some googling but nothing comes up for the model I have
I've got one on the shelf from memory, i'll get the numbers off it if I remember tommorow.
Hydraulic oil either 32 or 46
Swift plant spares in Sheffield. They will soon sort you one.
Y
yanmarb03
Does anyone know if the white plastic bush should be greased and spin on the metal shaft or should it be a tight fit and the black plastic guides allow the hydraulic lines to just slide though them ?
I'd imagine the black pulley should free rotate as the hoses pass over them ... no sense in wearing the hoses outer by sliding
