Pedrod355
Does anyone know if you can run this winch without having a return to tank line fitted? @ACEngineering
how many lines out of the motor ? 3 = RTT / case drain line![]()
I have reversible motors here with case drain lines ....can only see 2 lines, besides thinking about it would a motor capable of both forwards and reverse have a case drain???![]()
agreed ... looks like two .... looks like the valves on there are likely CLRVs so may be catered for within the relief's plumbing?Looks like 2 @V8Druid ?
be handy if that damned rag wasn't covering all the plumbing ... pity they only put two pix up on the listing
Yeh seen it was close buy. .If you buy it i couldn’t care less how many hoses it needs!It's over in callender, tell you what, if I buy it I'll check if it needs two pipes or more and I'll let you know
Be a handy tool for us plus it has JCB Q-fit hitch![]()
