I think you'll wear out the digger before you need to replace those
Is that a 9" (215mm) bucket? I have similar but even larger teeth on it.for leverage when fighting with a root or lump of concrete,
when trying not to unearth unknown services.
With the teeth removed it's abecause every bucket of clay blocks it solid.
My DX10Z came with Rhinox buckets, as you say seem very well made. Also have a good capacity.
I have a used e10 bucket in the yard it’s tidy too
I wouldnt worry too much my e10s handle 1.5t buckets without issue. Its just a case of knowing your limits or should i say what liberties you can take.What’s the biggest one of theirs you have? This 24” weighs 54kgshould I be worried?
24” digging bucket and 30” grading bucket. Which is wider than the machine with tracks inWhat’s the biggest one of theirs you have? This 24” weighs 54kgshould I be worried?
24” digging bucket and 30” grading bucket. Which is wider than the machine with tracks inI don’t think mine is as heavy as that though, maybe 40kg at a push.
I rang them this afternoon just to double check i’d been sent the right ones. They don’t make a lighter micro-weight bucket so they’re the same as 1.5t![]()
I don’t have anything to weigh it with but it’s a fair lump, 40kg max I reckon. Got some pics though.Would you mind checking your 24 for me? Model/weight if poss.
