New buckets
After looking around for some used buckets for my E10, decided to push the button on a couple of new ones from Rhinox yesterday. These seem pretty heavy duty, I don’t think the ones I currently have are anywhere near as sturdy!
Powerfab
Powerfab
I think you'll wear out the digger before you need to replace those :)
Is that a 9" (215mm) bucket? I have similar but even larger teeth on it. (y) for leverage when fighting with a root or lump of concrete, (n)when trying not to unearth unknown services.
With the teeth removed it's a :poop: because every bucket of clay blocks it solid.
It’s actually a 6”, thought it might be handy in tight spaces (other one is 24” so I can dig my foundations for house extension)
Jimbo69
Jimbo69
My DX10Z came with Rhinox buckets, as you say seem very well made. Also have a good capacity.
I got a 2ft6 digging bucket which is rhinox and must say it is alot better than the rest of what ive got.
Nick...
Nick...
Got a set of rhinox for my ecr25 volvo and loads better than the standard harford supplied buckets
Nick...
What’s the biggest one of theirs you have? This 24” weighs 54kg :rolleyes: should I be worried?
I wouldnt worry too much my e10s handle 1.5t buckets without issue. Its just a case of knowing your limits or should i say what liberties you can take.
Fair enough, it just makes the others look a bit lightweight :D
Vs 30” supplied with machine
Jimbo69
Jimbo69
24” digging bucket and 30” grading bucket. Which is wider than the machine with tracks in 🙈 I don’t think mine is as heavy as that though, maybe 40kg at a push.
Would you mind checking your 24 for me? Model/weight if poss.
When I called round for micro buckets, everyone except Strickland seemed to be bloody heavy. Mine handles 1.5t buckets OK, but I'm getting a lighter set. Depth is also an issue- the micro shell is a little shallower which must help loadover height.
I rang them this afternoon just to double check i’d been sent the right ones. They don’t make a lighter micro-weight bucket so they’re the same as 1.5t 👍🏻
That's why I'm going with a company who will!
Hg2702
Hg2702
regards rhinox I also had a bucket from them and it’s quality and if they think it’s the right weight there’s no reason they wouldn’t sell them
Jimbo69
Jimbo69
I don’t have anything to weigh it with but it’s a fair lump, 40kg max I reckon. Got some pics though.
